3 point strut brace? extra rigidity?
Postby 10k 20v » Thu Jun 16, 2005 10:06 pm
hey leon, does your cage go through to the strut towers???????
10k 20v
Postby CozmoNz » Thu Jun 16, 2005 10:47 pm
10k 20v wrote:when fitted i noticed the doors would creek as much when going up and down driveways with one of the rear wheels off the ground :D
sounds like a certain chevette i know of >.>
if your really worried, when the car has been a bit worn in (i dont know, few 1,000ks of thrashing lol), take it to a chassie strightener and have it checked... then you can see where your weak points really are....
Rayne For President!
CozmoNz
Postby jasestu » Fri Jun 17, 2005 1:18 pm
All_Fours wrote:hmmm, should've made the end plates higher so that the cross brace was straight and not bent, either that or used a thicker (taller) bar to compensate for the bends at either end, because those bends, particularly the sharper one on the driver's side, will bend more under load than you would think. It's still a good design, I just think it looks like they were attempting to make an "ultimate stiffness" brace, and could've done better :) Also the way that triangle has different angles on either side, coupled with the sharper bend on the driver's side, means the driver's side tower will have slightly more flex than the passenger side :)
Don't mind me, I'm just being pedantic
Valid points, however as yet I haven't seen an Altezza one without bends in it... Must be spatial limitations of the engine bay design.
jasestu
Postby Leon » Fri Jun 17, 2005 1:32 pm
10k 20v wrote:hey leon, does your cage go through to the strut towers???????
Nope ... too much $'s to do it.
Postby 10k 20v » Sun Jun 19, 2005 12:33 pm
yeh, ive been quotd 1500 to do one throuh to the towers, so thats what im gonna get :D
10k 20v
Postby wde_bdy » Sun Jun 19, 2005 1:10 pm
You have to start strengthening from the bottom up. Will also have cage tied through to strut towers and seam welding to go with these 3mm steel triangles at the base of the firewall.
Callum
wde_bdy
Postby Leon » Mon Jun 20, 2005 11:16 am
10k 20v wrote:yeh, ive been quotd 1500 to do one throuh to the towers, so thats what im gonna get :D
Mine only set me back $900, so I stuck with a cheaper cage option :). Not worth spending $1500 on a slow old AE92 sedan.
