caldinagtt wrote:if you think that the parcel tray sway bar or wotever to improve handling your an idiot it doesnt even bolt into the suspension its conected to plastic honelstly i thought this was a car forum take a look at the strut brace in the front oh look at that its bolted in with the suspension then u have a look at your parcel tray bs hmmmmm doesnt look like its bolted to the suspension but if you think it makes your car handle better go for it. i
Another case of opening mouth before engaging brain, bolted to plastic, look again, not bolted to suspension, look again, or perhaps you should look for the first time, or hand your license in now as you're obviously blind.
FYI the mounts for the cargo blind are welded to the suspension tower and to the outer body shell. There is also a brace that connects to the outer shock mount. The blind itself has steel brackets that bolt through the plastic to a steel mount with a full length 20mm (approx) diameter bar with 1.5mm wall thickness.
Whether or not it has any effect it's a bit hard to tell, but given the sturdy nature of the housing and the obvious attempts by Toyota to tie it into the rear suspension, I'd guess it's intended as more than just a cargo blind, or else they would have made the whole thing out of plastic and saved weight and expense.
And you wonder why people pour crap on your every post, with poorly researched drivel such as this, it's bloody obvious
BTW got a pic of all the "boost control crap" you removed from your car, I'd be interested to see just what it is you did remove. Hopefully not something important, or something useful, like the cold start fuel pressure solenoid
