GT-T I/C
Postby Santa'sBoostinSleigh » Mon Aug 01, 2005 2:16 pm
Still looking for info to the optimal I/C core size and piping diameter...
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby caldinagtt » Mon Aug 01, 2005 6:16 pm
just get 600x300x70 with 2 1/2 " piping thats wot i got works well does the job.
caldinagtt
Postby Santa'sBoostinSleigh » Mon Aug 01, 2005 6:58 pm
notice much lag?
what brand is yours and how much?
Santa's Mega Sale
Postby Malcolm » Mon Aug 01, 2005 7:48 pm
600x300x75 might be alright for someone with "450hp", but I wouldn't recommend going that big for much less than that...unless you're all about wank factor like most people these days....
Postby flygt4 » Mon Aug 01, 2005 7:52 pm
evo intercoolers tend to be a good size for most applications and i believe they dont flow too badly..
flygt4
Postby Santa'sBoostinSleigh » Mon Aug 01, 2005 7:55 pm
so somthing like 500x250x60ish?
Santa's Mega Sale
Postby Malcolm » Mon Aug 01, 2005 8:26 pm
that would probably be better
even an easier to get (and cheaper) 450x300x75 would be alright, although possibly still on the large side.
Postby Santa'sBoostinSleigh » Mon Aug 01, 2005 8:32 pm
most seem to have 3" in/out, so just use a reducer to 2 or 2.5" i guess
do the in/outs have to be at the top or bottom or anything?
Santa's Mega Sale
Postby Malcolm » Mon Aug 01, 2005 8:36 pm
AFAIK the ideal set up is to have one at the top and one at the bottom, this makes the airflow spread more evenly through the core, whereas when both are at the top (or bottom) you tend to get more airflow through the tubes closest to the inlet/outlet (to what extent I'm not sure).
Postby Santa'sBoostinSleigh » Tue Aug 02, 2005 12:03 am
these look any good/value for $?
http://www.trademe.co.nz/structure/auct ... d=32443878
might be a bit small? 280x300x76
i really should measure what the standard Caldina one is
Last edited by Santa'sBoostinSleigh on Tue Aug 02, 2005 12:14 am, edited 1 time in total.
Santa's Mega Sale
Postby Santa'sBoostinSleigh » Tue Aug 02, 2005 12:04 am
oh yeah and whats the pros/cons of bar&plate vs tube&fin?
Santa's Mega Sale
Postby TWSTD » Tue Aug 02, 2005 2:00 pm
my (totally unbiased of course) suggestion for intercooler:
http://www.drivenperformance.co.nz/scri ... roduct=503
Re piping, Im using 2" from turbo to cooler, and 2.5" from cooler to T/B - I notived NO extra lag when installing this cooler setup and still on factory turbo.
We of course (un-ashmed self plug) have all the silicone you may need for this install: http://www.drivenperformance.co.nz/scri ... ategory=19
Clocking the comp housing is simple and striaght forward - you just need to tack mounting points on as the WG actuatory bracket needs to live in a new place (unless you are going external, in which case you can skip that part).
Good luck with it :-)
A
Click here!
TWSTD
Postby Santa'sBoostinSleigh » Tue Aug 02, 2005 3:13 pm
is that the cooler you are using TWSTD?
has it got a 'brand'?
Santa's Mega Sale
Postby TWSTD » Tue Aug 02, 2005 3:39 pm
no its not, and no it doesnt. The one I have is an odd ball race radiators one I got 2nd hand some time ago.
Brand is largely irrelevant - its the design and quality of contruction that you should be concerned with regarding a cooler.
Click here!
TWSTD
Postby Santa'sBoostinSleigh » Tue Aug 02, 2005 3:45 pm
ok maybe what i should have asked is "is that the same size/style as yours"? :oops:
Santa's Mega Sale
Postby TWSTD » Tue Aug 02, 2005 5:59 pm
No, mines an odd-ball size, but were i going to do my system again the size i suggest to you is the one I would use. Yes same style - a well designed bar and plate.
Click here!
TWSTD
