Okay guys, ball park figure- how much for a set of neons plus installation?
Aarrrgghh! Can't believe I'm doing this! Must- not- press- submit key...
Oops, too late
Why not, they'll look good on my curren... now for the clear indicators...
AJz wrote:well for a start front and rear are illegal
if you are having neons on your car, just like with any other non factory lights, make sure they are legal.
give this a read.....under cosmetic lighting...
http://www.ltsa.govt.nz/vehicle-safety/get-your-lights-right.html
ltsa.govt.nz wrote:Fitting requirements
Cosmetic lamps can be any colour as long as they meet the following requirements.
* They must be angled downwards and fitted so that the light source isn’t directly visible from the front or back of the vehicle (this will prevent the lights distracting, confusing or dazzling other road users). See diagram below.
* You must not be able to see the light source (lamp) from anywhere in the shaded zone.
* They should only give off light that is spread out (diffuse) rather than light concentrated in a beam.
* They must not be positioned close to essential lights such as headlights or indicators.
* They must not flash, pulse, fade in and out or change colour.
* They must not revolve, rotate or move in any direction.
rage wrote:okay so reading that ltsa site. u can have neons of any color and around all sides of the car AS LONG AS you cant see the actual neon tube ?
