Take a look inside a typical front engine RWD gearbox, one with the
input and output shafts inline. Then explain to me how 3rd gear works
with only one pair of gears engaged
Granted, there are some fixed and some variable losses involved in
gear transmissions, so the efficiency will tend to drop off a little when
the box is operating at less than rated power.
I don't have any reference data on what happens to the efficiency
when a box is operated at twice it's rated power. I'd guess that it would
probably drop, as the tooth loading would most likely exceed the ability
of the lube to keep a film between the sliding surfaces, and metal to
metal contact would occur.
What I can say with some certainty, is that if you take a box rated
for 100 kW input @ 96% efficiency and feed it 100kW, it will reject 4 kW
primarily in the form of heat. Take a second box rated for 200 kW input
@ 96% efficiency, feed it 200 kW and it will reject 8 kW. Input speed,
ambient temp and other conditions being equal.
Operation above and below the rated conditions, with cyclic loads and
widely varying speeds and temperatures, will affect the efficiency and
the amount of heat rejected. How much affect is pure speculation.
Cheers..... jondee86
