Massive Hesitation - FIXED (The most simpliest thing)
Postby Skidman » Tue Oct 18, 2005 8:47 pm
If all this octane stuff that Mmm Boost says it might be caused by is correct, then check your timing, as lower octane fuel has a higher callorific value and burns faster, therefore you mixture may be combusting too far before 12 degrees after TDC...etc
I highly dought that this is the problem.
Hondas are made for people who dont know better.
Skidman
Postby gurutasker » Wed Oct 19, 2005 6:47 pm
Well, checked the TPS.. and it was out a little, but nothing really notable. Adjusted it slightly and took it for another drive.
Problem seems to be getting a lot worse now, happening when cold, all throughout the rec-range. Thought it could be a fuel related issue? Had a quick check and the fuel pump is going and there's pressure in the lines.
Any ideas? Unless someone locally is keen to try and fix it, i'll probabley end up taking it into toyota.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Postby gurutasker » Wed Oct 19, 2005 7:41 pm
Right... well, i found the problem, and the solution, and in fact it was just a thought that crossed my mind, but the simpliest fix i've ver done :lol:
Symptoms: As above
Cause: NO FUEL
Reason: Fuel gauge was stuck/broken
Was laughing all the way home.
(Probabley just got some water in the tank and after leaving it for a while it settled, combined with low fuel was sucking in half/haf..)
gurutasker
Postby Mr Revhead » Wed Oct 19, 2005 8:47 pm
:lol:
no comment
Postby no_8wire » Wed Oct 19, 2005 9:14 pm
Some times its the simplest things that stuff you up... :D
no_8wire
Postby gurutasker » Wed Oct 19, 2005 9:34 pm
Mr Revhead wrote::lol:
no comment
Don't worry...you can comment all you like when you get up here :P
gurutasker
Postby Spannergal » Wed Oct 19, 2005 11:11 pm
gurutasker wrote:Right... well, i found the problem, and the solution, and in fact it was just a thought that crossed my mind, but the simpliest fix i've ver done :lol:
Symptoms: As above
Cause: NO FUEL
least you didn't end up paying toyota $160 for $20 worth of fuel - wgtn branch has had a customer who did that 8O
Spannergal
