All i did is cut off that little box for now untill i get sum pipe
(hope in the next week or 3)
And removed the bottom of the cold air box put in a flat k&n in
works nice.
Now ive got thart nice lould 4AGE noise
jailbird wrote:Been there
works nice.
B1NZ wrote:jailbird wrote:Been there
works nice.
I thought the filter sat between the 2 parts of the airbox? You would have probably been better leaving the bottom part on there as you are now just sucking hot air form the engine bay like my stupid pod filter is!
gordon77 wrote:this is where my valve thingie is sitting (circled) the arrow points to where the vacum line for the aircon will go. i am going to drill a hole in the pipe and put the air temp sensor in with the factory grommit around it (off the old airbox)
http://i20.photobucket.com/albums/b233/ ... 240555.jpg
B1NZ wrote:gordon77 wrote:this is where my valve thingie is sitting (circled) the arrow points to where the vacum line for the aircon will go. i am going to drill a hole in the pipe and put the air temp sensor in with the factory grommit around it (off the old airbox)
yeah thats what i did with my 20v blacktop, Used the rubber grommet off a factory toyota airbox, the filter now sits where the resonator used to be in the front guard and gets air from straight in front of the factory spotlight gap.
Looks like you've done quite a good job there fella, Its nice to see someone taking their time and doing it properly rather than rip sh*t and bust![]()
Are you going to remount the sensor box thing thats now dangling on top of the gearbox somewherein the line?
And nice polished cam cover, how did you do that?
You dont happen to still have the old airbox etc do you?
