Non superstrut ae101 lowering springs to fit ae92??
Postby trueno_20v » Fri Nov 18, 2005 9:58 am
again, will these non superstrut springs fit a cynos?
ADMIN EDIT: signature too large
trueno_20v
Postby Mr Revhead » Fri Nov 18, 2005 10:17 am
NO
a cynos is very different
Postby trueno_20v » Fri Nov 18, 2005 1:11 pm
Cheers :D
trueno_20v
Postby TRDWGN » Fri Nov 18, 2005 9:56 pm
Mr Revhead wrote:s/s to non s/s fronts? they are different heights.....
the spring platform on s/s is higher that non s/s....
were they superlows? and did they require spring compressors to fit?
No they were just lows, obviously i couldn't compare unsprung heights however they fitted (And that was the original question :lol: ) and the car sat around an inch lower in the front than its std height... I paid the profesionals to fit them (as i didn't have the tools to easily crack the balljoints at the time) so am not sure if they used compressors.
I would hazard a guess that the difference in height is so minimal that it wouldn't change the suspension geometry or ride height F all?
TRDWGN
