Air Filter
Postby vvega » Sun Dec 18, 2005 7:01 pm
ROBODISCO_20v wrote:
Mr Revhead wrote:value for money......
now, would really trust a $35 filter from repco??
The ones with the inverted bit in the top are made by simota. So there is nothing wrong with them.
The HKS styled foam pods & the see through stainless ones are a bit doggie.
vvega
I've talked to plenty of people who have gone from K&N in the factory air box to pods & have noticed an improvement. But like I said a pod in a cold air box would give you the best results.
It would be interesting if NZPC did a article on this subject.
http://www.max-boost.co.uk/max-boost/im ... r_test.htm
http://www.mkiv.com/techarticles/filters_test/1/
dude not been horible offensive or silly but id like to see some attual dyno results
i dont know how many time ive herd people swear they have more power only to be put on the dyno and have a loss in the low end or midrange
just tring to extract some fats from a big pond of bulshit we call the internet
v
vvega
Postby Al » Sun Dec 18, 2005 7:04 pm
ROBODISCO_20v wrote:This is very debateable.
From my experience a pod filter gives better results than a high flow panel in the factory air box.
Yes you will get even better results if you put the pod in a cold air box. Factory toyota air boxes just dont flow that well.
I like to talk numbers. My car can trap 110mph (trapspeed = power) down the strip. It uses the early factory airbox with a drop in panel filter. Can't be too bad.
Al
Postby tomo1985 » Sun Dec 18, 2005 10:08 pm
Why would putting a a pod and cold air box cause a flat spot in the rev range? shouldn't it just be the same if not better if a well designed box is made. I have had pods with out a cold air box and in that case you are better off using the standard system. Now i have a fiberglass box sealed from the engine bay and im sure it makes a small difference. But you cant really expect a huge difference on a n/a.
tomo1985
Postby vvega » Sun Dec 18, 2005 10:10 pm
they spend a hell of a lot of money on reasurech to make the airbox do its job well
if anyone thinks they can wipp down and buy a chepa bit of alloy and make something better there only folling themselves
v
vvega
Postby The_Sorrow » Sun Dec 18, 2005 10:20 pm
Sorry to hijack (its partially related)
I'm in the middle of making this
http://www.4age.net/tech/coldair.htm
Anybody care to guess on the result of doing this for a 20V Silvertop?
Or would it be better to just duct from the front to the factory airbox?
Does anyone ACTUALLY know? Futhermore, can anyone actually PROVE it?
Just another sh*thead wanker apprentice :P
The_Sorrow
Postby vvega » Sun Dec 18, 2005 10:24 pm
The_Sorrow wrote:Sorry to hijack (its partially related)
funny how theres never any dyno sheets :D
vvega
Postby The_Sorrow » Sun Dec 18, 2005 10:36 pm
Dyno's are for cabbages ow, it's by how many pounds of VTEK its running :lol:
But seriously, does anyone actually know?
The_Sorrow
Postby ROBODISCO_20v » Tue Dec 20, 2005 7:33 pm
All the honda boys in Whangarei used to put their pods in the guard like that but it recked the filters pretty quick from all the shit they picked up & not to mention the water that got in there. Then James at workshop X started making carbon cold air boxes for them.
As for the pod vs. std air box I guess it's just one of those things that every one will agree to disagree on.
I still managed 102kW with my HKS pod sucking in all that warm air
ROBODISCO_20v
Postby vvega » Tue Dec 20, 2005 7:42 pm
now take it off and tri a pannel in you stock airbox and redyno
i woudl be very interested in your results :D
remeber to go to that same dyno :d
v
vvega
Postby Santa'sBoostinSleigh » Tue Dec 20, 2005 7:48 pm
ROBODISCO_20v wrote:It would be interesting if NZPC did a article on this subject.
NZPC dont know sh*t from breakfast
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby no_8wire » Wed Dec 21, 2005 9:56 am
the only advantage I can think of in replacing your factory filters is
1. It sounds cool! :lol:
2. You have a VERY indirect air route to your filter...eg aw11...
please excuse the very bad paint... :oops:
that air has a whole lot of 90 degree bends it needs to do...
no_8wire
Postby ROBODISCO_20v » Fri Dec 23, 2005 5:54 pm
vvega wrote:now take it off and tri a pannel in you stock airbox and redyno
v
Any body got an AE111 BZ-G air box I could borrow?
I've done to many mods scince i last had it dynoed to get a fair compairson
& Yes who ever writes the NZPC mod section isn't the most on to it person, & I would have to say they know little or nothing about toyotas from the replys I've read.
Here's a pic of my mates cold air box in his tegs.
http://profiles.nzhondas.com/profile.ph ... &photoid=2
http://www.workshopx.co.nz/images/devt/plen2.jpg
Last edited by ROBODISCO_20v on Sun Jan 22, 2006 12:17 pm, edited 1 time in total.
ROBODISCO_20v
Postby RS13 » Fri Dec 23, 2005 7:46 pm
I went from factory airbox to $30 cheapy pod from Repco, went from 8 to almost 9psi, sounds pretty damn hot too.. Although, I do notice the heatsink effect, if I've been sitting in a drivethrough or traffic for anything more than 5 minutes, it seems remarkably slower until I get some airflow going through it again. That, and I've gone from around 450kms a tank to around 350kms a tank of fuel, same driving style.
So, for me personally;
Pros: Gained 1psi, more noise (sounds like a jet!), feels less strained over 5000rpm.
Cons: Easily affected by engine bay heat, hugely increased fuel consumption, non-oiled, so can't reuse it.
Also, after speaking to my engine builder, he told me I'd get no more filtration with the pod than the factory panel, both being paper, just better airflow. So for my $50 (pod and adaptor) I think it was worth it. Bear in mind, it was on an RB20, which is markedly different to a n/a 1600! My next mod is to build a cai..
RS13
Postby Mr Revhead » Fri Dec 23, 2005 8:48 pm
are you sure its filtering the same?
Postby TRD001 » Fri Dec 23, 2005 10:07 pm
Buy a panel TRD Filter, It was desinged by TRD Specialists who desinged it to suit Toyota's It's not just some universal filter that fits like a ford laser, As for POD'S They are not something that you would notice a mahor difference in my opinion.
TRD001
Postby BZG Wagon » Sat Dec 24, 2005 12:19 am
RS13 wrote:Cons: Easily affected by engine bay heat, hugely increased fuel consumption, non-oiled, so can't reuse it.
I thought more air-flow would = a leaner running engine thus less fuel consumption?
...unless you drive it harder...
BZG Wagon
Postby ROBODISCO_20v » Sat Dec 24, 2005 10:06 am
Your factory ecu will compensate for any small changes in air flow, like installing a high flow filter. More air equalls better combustion
TRD001, how many high performance cars do you see that are still running the standard air box :?: The only ones I've seen are race cars and they probarbly have to run them to to keep with the class rules.
If you still want a high flowing factory air box & K&N type panel, get one off a VN onwards commodore & retrofit it to your toyota. But why bother when you can fit a fit a pod :?:
ROBODISCO_20v
Postby vvega » Sat Dec 24, 2005 11:36 am
ROBODISCO_20v wrote:Your factory ecu will compensate for any small changes in air flow, like installing a high flow filter. More air equalls better combustion
how many do you see with a pod fitted.... im talking real racecars
they all have trial and error fitter airbox's
some teams go though 30- 40 setups before they get one that has good gains
do you have the kind of money to do that to get gains from modding your factory airbox ???
i even know of people that have been running open trumpets and now runn a airbox again finging they have more power
its called hemholz im sure you would have seen it mentioned lots in redmists posts :D
v
vvega
Postby jasestu » Tue Dec 27, 2005 2:45 pm
vvega wrote:they spend a hell of a lot of money on reasurech to make the airbox do its job well
Very valid point, manufacturers do spend a lot of money ensuring correct airbox design. However, one goal of a factory airbox is to minimise noise (as well as to maximise power across the rev range). I'd suggest that an aftermarket option which doesn't have to balance these conflicting goals may offer a performance increase (at the expense of a quiet induction).
jasestu
Postby ROBODISCO_20v » Sat Jan 14, 2006 2:30 pm
I was just reading an article in the lates zoom magazine on tuning a Falcon XR6 turbo. They were doing dyno runs after doing the mods like exhaust only(245kW), the adding a piggyback ecu etc. They managed to get 308kW :!: at the wheels. Standard was just over 200kW(The factory rating is only 195kW) Then for a laugh they did a run with the factory air box open so it didn't have to breath through the filter & they got 320kW :!: Thats an extra 12kW at the wheels just by removing the restrictive factory air box set up! You can pick this mag up from most bookshops etc & read it for your self if you dont believe me.
ROBODISCO_20v
Users browsing this forum: Bing [Bot] and 7 guests
