I have what appears to be a gen 1 1G-GTE - yellow ECU plugs
and injectors - in the yellow wreck in the garage.
Also, the hoods on the injec connectors are brown and grey, however
the ECU's label only has '1G-GT" on it ??
It has large ballast resister for injectors under the bonnet - has three
wires: presumably one for each bank of injectors and the third going to
ground, tho it rejoins the wiring loom before doing so. I would think that
without it, the injectors will pull too much juice and you'll either fry the
driver circuits in the ECU or the injec's will pop.
To check for your particular engine, confirm the impedance of
the injectors - if the are 2.8 ohms you will need the resister if they
are 13 or so ohms you will not.
lofreq wrote:no battery charger here so its gonna have to wait till tomoro, i'll get one from warehouse - bah another $99 gone (i think they are that much?)
