Mobil 1 in a 4AGZE
Re: oil
Postby fivebob » Sun Jan 15, 2006 11:53 pm
ATOYOTA wrote:yea alot of the the cars that get serviced at toyota are castrol 10 30
magnatec that does new models and old as far as performace goes thats up to u but i do think 5w50 is a bit thin
But 5w-50 is thicker than 10-30 where it counts, i.e. when the oil is hot :roll:
Postby sergei » Mon Jan 16, 2006 12:15 am
Why people think that the thinner the oil the bettter it is for engine?
it is defently not, it is better for performance/efficiency but not really for protection, well actually protection is not totaly dependand on viscosity anyway - there are factors like film strength, flash point, detergancy etc..
The advantage of synthetic oil is not that they are thinner (castrol R 10w60 is good example of really thick oil when hot), but because they are designed to have certain propeties, and have much less impurites / neutral substanses as mineral do.
Postby touge rolla » Mon Jan 16, 2006 12:56 am
i've found that shell oils burn badly from 10w40, 15w4o and 20w valvoline armour all 15w40 is not bad at all, and cheap :D
touge rolla
Postby Allister S » Sun Jul 01, 2007 10:23 pm
Hey, I found this post in a search and thought it was fairly interesting.
I agree with the comments on the 5W oils being a bit thin but on the topic of Mobil 1 there is a bit of history.
I first put my early spec AE92 GZE engine in my car in 1994 and started using Mobil 1. But at the time the common Mobil 1 was a 15W-50 grade. I've done 100,000 hard kms since and have never burnt a drop of oil and the engine looks brand new inside.
I still use the 15W-50 Mobil1 but I have to get it ordered in whenever I need it (Even Repco can order it in) as I never see it on the shelf anywhere. For a time Mobil even only had it as a motorbike oil - Racing 4T but they told me it was the same 15W-50 oil I'd been using.
So from form my experience Mobil1 seems like a good oil but only the thicker 15W-50 grade.
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
Postby Mr. Mainstream » Mon Jul 02, 2007 2:56 pm
method wrote:Ive heard lots of bad things about magnatec and turbod cars.
it killed one of my B6-T engine
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby BlakJak » Mon Jul 02, 2007 3:07 pm
And it ran beautifully in my 3SGTE.
BlakJak
Postby Mr Revhead » Mon Jul 02, 2007 3:23 pm
how?
Postby Bling » Mon Jul 02, 2007 3:26 pm
halfway through a 5 minute skid au.
Postby Mr. Mainstream » Mon Jul 02, 2007 4:04 pm
BZG|Bling wrote:halfway through a 5 minute skid au.
Lies :lol:
No Idea. in my 2nd 323 from which i scoured the engine from my first 4wd one after doing the convertion and getting it running mint i did a oil change with magnatec and 2 days later it started blowing horrible smoke and all sort so gave up on that engine.
could just have been a freek thing but saying that ive heard bad things about magnaTEC and B6-T's on www.fordlaser.com
Valvoline engine armour has been good in several off my cars'
Various Others
Mr. Mainstream
Postby Allister S » Mon Jul 02, 2007 7:12 pm
I've used Magnatec in 2 GTS-t skylines and a GT Legacy without any trouble - all Turbos and high km cars. Used the standard GTX every 3rd oil change - some guy said to (can't remember who or why....)
But then I've never had an engine blow up on me so maybe any oil would've been ok??????
Allister S
Postby fivebob » Mon Jul 02, 2007 8:31 pm
I've had one 3S-GTE blow up using Magnatec and one blow up using Mobil-1. Not sure the oil had anything to with either experience :lol:
Postby Mr Revhead » Mon Jul 02, 2007 9:16 pm
fivebob wrote:I've had one 3S-GTE blow up using Magnatec and one blow up using Mobil-1. Not sure the oil had anything to with either experience :lol:
i can only see 2 common factors there! :lol:
Postby matt dunn » Mon Jul 02, 2007 11:29 pm
We found that synthetic oils dont absorb heat from the engine as much as non-synthetic.
Good for a NA car,
But on a turbo car, they dont remove the heat from the shaft enough for some applications.
Postby fivebob » Mon Jul 02, 2007 11:43 pm
matt dunn wrote:We found that synthetic oils dont absorb heat from the engine as much as non-synthetic.
Which synthetics? Not all of them behave the same.
Postby matt dunn » Mon Jul 02, 2007 11:53 pm
Particulary Older Castrol R, which we had turbo trouble with,
and also the New Castrol Edge which is the same stuff.
Have had a few new turbo's fail at times and have had the turbo repairer say it was excessive heat in the shaft from synthetic oil.
We did an oil change at the track, from edge to Castrol Protec,
Engine temps dropped 20 deg and oil temps gained 20 deg.
Still use castrol now, just the turbo-tested stuff.
Postby fivebob » Tue Jul 03, 2007 12:42 am
Hmmm, I wonder what is in the Castrol package that causes that. Generally speaking synthetic oils have a better specific heat capacity than mineral oils, meaning they should be better at extracting and transfering heat. :?
Mobil-1 does not exhibit the same characteristics. From watching my oil temp vs coolant temp, the oil heats up at the same rate from cold and generally runs about 5-10°C hotter than coolant. It also responds to engine load quicker than the coolant. Typically the oil will rise 5°C before the coolant temp starts to rise.
