True-No-Turbo wrote:solberg Fan wrote:Measure the block and see if it has any warp in it. I had a copper gasket made up for me, skimed the head, no pitting on the block used the VHT copper stuff and put it together. Had no compression in two cylinders.
What is the advantage of flat unbeaded copper or metal gaskets? are you trying to increase quench efficiency or compression ratios or what?. Are they superior to standard gaskets in what way???
Ive never used them before? only on some diesels but they were shimmed type gaskets to get the correct compression ratio back after milling.
