All_Fours wrote:this article refers to the vane type AFM as measuring air volume:
http://www.autoshop101.com/forms/h34.pdf
sergei wrote:AFM is designed to work under atmospheric pressure, if you use it in pressurized application, it would result in incorrect output due to bernoulli equation...
I wonder if the denser air does cause more deflection for a given volume, but not to the same ratio as the increase in pressure, so air at 2bar abs. might increase deflection 50% more than air at 1bar abs. for instance.
Bazda wrote:whats this 153hp................
