TWSTD wrote:fivebob wrote:If you're going to use it with an aftermarket ECU then in reality it doesn't matter if the curve is exact
I actually intend to use it with a factory ECU in a vehicle that uses a 2 bar sensor from factory
Assuming you're changing injectors at the same time, then you need to know the curve of the stock sensor first to see if it will be too lean at any points. If you're planning on using stock injectors then forget it, chance that it work is minimal.
The other problem is that you will be altering the advance curve, and most likely in the wrong direction unless you're planning on running very high octane race gas, or some sort of ignition signal modifier.
In short it's not something I would recommend as you're more than likely to destroy an engine, and that's (probably) worth more than setting it up properly with an aftermarket ECU in the first place.
