Compression & 1JZ.
Postby Silent Knight » Wed Feb 22, 2006 10:19 am
matt dunn wrote:
Silent Knight wrote:I'm really after the higher compression to get a better response etc.
If you are after response why go single turbo?
I'm not going single turbo at the moment and I haven't fully decided whether I want to yet.
The other option I was concidering is the HKS T3G kit for the 1JZ which should be adequate for around 300+rwkw but that's next year sort of plans.
Silent Knight
Postby Si » Mon Feb 27, 2006 12:41 am
just read the article in NZPC about that red jza70, (the article sucks btw. nzpc are fags)
the car is a pretty ruthless piece of work however,
dirty big turbo, couple of extra 850cc injectors, fuel pumps, cam gears/cam grinds, ecu's and out cranks 488rwhp 8)
Current: , '96 SubaruImpreza
Si
Postby Silent Knight » Mon Feb 27, 2006 9:03 am
I can't stand NZPC so I'm not going to read it. :P
Silent Knight
hmm
Postby Timmo » Mon Feb 27, 2006 12:39 pm
well in terms of compression, the jzz30/31 update for the 1996 year upped the compression of the 1j when the moved to the single turbo. As far as i know the internals werent changed but the head was of course (addition of VVT-i)
How much are you planning to spend? You have to consider importing a modded soarer from Japan- can pick one up for around the 10g mark and most of the work is done for you (although they often require a tune to match our cr*p fuel, you have to import a 1996 and newer model due to frontal impact compliance which means single turbo 1j :)...if you do your homework and use a good importer you can make some substantial savings...often modded cars are about the same price as orginal cars.
Try www.cwicars.com.....
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby Silent Knight » Mon Feb 27, 2006 12:40 pm
No I'm not importing another Soarer thanks.
Silent Knight
Postby Si » Mon Feb 27, 2006 10:15 pm
need i say more :P
Si
Postby gmacrae » Tue Feb 28, 2006 11:29 pm
God i wish people would work out that twin turbos dont spool faster than a single. :roll:
Anyway, about the stock ecu teaching itself to run bigger injectors... I realise it does this to an extent (open loop), but when running closed loop (on boost) it just sticks to the preset maps with no adjustments... this is what i've been told by a few people now, can anyone confirm this?
You should get 300rwkw from a stock 1j bottom end with the right tune. But from what you're saying you should seriously consider making a 1.5jz with thick HG. If you're after response, 500cc's and higher compression will definitely do the trick :)
It would be interesting to see how well the stock 1jz ecu runs a 1.5jz with small single (450hp) and 440cc+ injectors. You'd need to make no more than about 15psi with stock ecu so the boost cut defender isnt messing with the map signal too much.
Just tossing ideas round, keep us informed Hanre :)
Gene
gmacrae
Postby matt dunn » Tue Feb 28, 2006 11:55 pm
gmacrae wrote:God i wish people would work out that twin turbos dont spool faster than a single. :roll:
Gene
I disagree there,
We have run a 2JZ on both twin turbo setup and one with a big single.
the big single made more power, about 650 atw,
and the twin setup made 510.
The Single has a very narrow power band and has a lot of lag and then hits hard,
The twin setup has a very wide powerband with smooth and early power delivery.
Matt
Postby Si » Wed Mar 01, 2006 12:01 am
what RPM torq converter have you got/ordered hanre?
its pretty high is it not?
Si
Postby Silent Knight » Wed Mar 01, 2006 6:09 am
Si wrote:what RPM torq converter have you got/ordered hanre?
I've already got a 3000RPM Stally sitting in the shed ready to go in. My mufflers arrived yesterday so the exhaust will be getting made soon and then I'll order the Shift Kit in the next 2 weeks or so.
Gene the spool time of turbos depends on your setup. I've seen many 1JZ boys in Australia get brilliant results from TTs. I've seen them TD04s and HKS T3G kits and who knows what other combinations.
I was concidering going 1.5JZ but if anything happens with that it will be next year. I was planning on rebuilding my bottom end next year regardless so I guess it might be worth it if I source a 2JZ bottom end and get some good internals for it. Will give me much enjoyed extra torque. 8)
Also if I do the 1.5JZ I definately won't leave it up to just the stock ECU to handle things. My SAFC is sold and I'll be looking at getting a GReddy Ultimate soon to through into the mix. :D
Silent Knight
Postby Si » Wed Mar 01, 2006 8:20 am
i know in a a70 a 1.5jz with stock twins wont fit too well (turbo/firewall issue)
not sure about the jzz30s however. might be something to think of as it would be a pain to get good twins then find the rest wont fit :lol:
Si
Postby Silent Knight » Wed Mar 01, 2006 10:20 am
From what I can remeber John didn't have much trouble fitting the 1.5J in there so I wouldn't suspect I'd have problems in the Soarer really....
Got some bling in the mail for her yesterday aswell... 8)
http://forums.mk3supra.co.nz/test/zorst/zorst.JPG
Silent Knight
Postby Ako » Wed Mar 01, 2006 10:40 am
Gene
I disagree there,
Matt
Yeah, now how about if they were actually equal setups? I could create an argument to go the other way as well!
Ako
Postby the fallen303 » Wed Mar 01, 2006 11:31 am
what was the turbo's that were used in the two setups matt? i'm interested to hear about the twin setup, and dad wants to know about the single.
true house of JZ
Stay true to the origin
the fallen303
Postby matt dunn » Wed Mar 01, 2006 7:58 pm
Ako wrote:Yeah, now how about if they were actually equal setups? I could create an argument to go the other way as well!
What do you mean by equal setup's?
Postby gmacrae » Wed Mar 01, 2006 11:06 pm
EXACTLY. I cant believe people cant see the common sense side of this argument.
Matt Dunn: Of course the twins spooled faster in your comparison, the combined twins obviously have less flow capacity than the single. Compare apples to apples. To put it very simply, if you have a twin setup making say 500hp@20psi vs a single setup making 500hp@20psi on the same engine, if anything, the single will spool faster (slightly) because it has only a single turbine to spool vs 2 turbines (though each one smaller). There is much less rotational mass in a single than there is in a couple of twins. Also less bearing resistance - not that these make a huge difference.
The only way a twin setup will spool faster than a comparabily sized single is if they're run sequentially, that's basically where the myth that "2 turbos are faster than one" came from.
gmacrae
Postby matt dunn » Wed Mar 01, 2006 11:11 pm
gmacrae wrote: Of course the twins spooled faster in your comparison, the combined twins obviously have less flow capacity than the single. Compare apples to apples. To put it very simply, if you have a twin setup making say 500hp@20psi vs a single setup making 500hp@20psi on the same engine, if anything, the single will spool faster (slightly) because it has only a single turbine to spool vs 2 turbines (though each one smaller). There is much less rotational mass in a single than there is in a couple of twins. Also less bearing resistance - not that these make a huge difference.
Ok, I see what you mean.
Postby gmacrae » Wed Mar 01, 2006 11:24 pm
Silent Knight... Keep an eye on trademe for a 2j. I've seen a few on there in the last few months, usually around the 1k mark with loom and auto on them. Coz 1j and 2j have identical bore size you could use your 1j pistons. The stock 1jz-gte parts have oil squirters unlike the 2jz-ge ones right? This should drop the CR and would be a pretty tough setup.
BTW, i've got a set of high flowed 2j turbos here (buggered bearings), not sure if your ct12a's could use any of the wheels? If so, lemme know, they're gathering dust :roll:
gmacrae
Postby Si » Wed Mar 01, 2006 11:44 pm
ill take them off your hands in exchange for beer :)
Si
Postby the fallen303 » Thu Mar 02, 2006 10:56 am
1j pistons won't work in a 2j block. they are the right bore, yes, but the pistons themselves are a different design, and sit to high. if you want to use them, you have to get them skimmed to match the top of the block, which i think is a $&#$% stupid idea, hence why the 2jz block i bought is basically going in the bin now.
true house of JZ
the fallen303
Users browsing this forum: Bing [Bot] and 30 guests
