Need some specific advice on track setup AE101
Postby Bazda » Wed Apr 26, 2006 8:04 pm
CircuitLevin wrote:
Bazda wrote:
CircuitLevin wrote:
Bazda wrote:
CircuitLevin wrote:
Bazda wrote:I have camber plates to fit ur car, soem guy off trademe bought them but i havent heard back from him, wanting $225 for them
Thanks, what brand are they? What degree movement do they have?
Cheers!
no brand name, I use them on my car, they adjust +/- 5 deg
Ok, seem to have enough movement, but I am kinda over not buying high quality parts for my cars, especially suspension on a track car.
these are very good quality and well made, I have pulled them apart to inspect them as well, i wouldnt use crap on my car, especailly when its 400hp. I will also be doing some track racing with mine.
They have a proper ball swival mount in them.
also when u put more camber on it puts on more caster at the same time as when u mount them onto the car they are offset slightly.
I would get longer ball joints to correct the geometry...
How do you know they are very good quality? What grade hardware was ued? What grade alloy? How were they machined? To what tolerances? What grade bearing? etc?
platform is 6061 alloy
the casing for the bearing is SAE9254 steel
tolerances I will haev to ring the factory for their specs.
but the guy on trademe got in contact so they are sold now..
Users browsing this forum: Google [Bot] and 3 guests
