Blacktops when cold
Postby rallymazda » Sun May 07, 2006 8:01 pm
My symptoms just feel like someone someone pulls the handbrake 1/2 on for that rev range when cold.
Not a miss or anything.
yep
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Lanius » Sun May 07, 2006 9:28 pm
sounds about right.
Lanius
Postby demis » Sun May 07, 2006 10:04 pm
i thought it could be was the nock sensor
any other idears ??
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby AceSniper » Sun May 07, 2006 10:57 pm
un even fuel presure? factory the vacume line on the fpr is off one cyl (unstable)
AceSniper
Postby dotdog » Mon May 08, 2006 7:55 am
Yea it does feel like someone has pulled on the handbrake, and mine isnt a miss its just like the motor doesnt want to go
Ive got brand new trd leads on mine and my plugs are only 15000km old. How do you clean out the t/bs?
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby Dell'Orto » Mon May 08, 2006 5:21 pm
Take it in to Tony and go "Oi, clean these out" :lol:
Nah, just take off the plenum and trumpets, and blast em with some carb cleaner.
Postby Miss_Trueno » Tue May 09, 2006 9:08 pm
Same symptoms as mine. I've found nothing to cause it, nor has a mechanic. I baby it when it's cold, try to change really low.
Miss Trueno - now piloting the Flying Baked Bean KP Starlet!
Miss_Trueno
Postby demis » Tue May 09, 2006 9:49 pm
i still think its the shit fuel we get here
demis
Postby matt dunn » Wed May 10, 2006 12:48 am
Here was the original theroy on the catch can fix.
When the pistons are cold they are smaller, and let more blow by past the rings pistons etc into the sump.
This then enters the engine via the PCV system and enters the combustion chamber where the oil vapours cause detonation.
The ECU senses this ( only in the most detonation prone zone which is the RPM range where this ocours) via the knock sensor and retards the ign timing. This causes the lack of power, or handbrake is still on feel to the car, during that particular rpm range and only when cold.
As said earlier, some have tried catch cans with no effect, so this may or may not be the case.
On my particular vehicle it only really occours in the first 4 minutes of each day then will not happen again untill the next day, or the car is left for more then 4-5 hours to cool. This makes it a bit hard for me to check, as the wife takes the car to work each day, and I am not getting up early to try and checkm it before work.
As I have acess to a scan tool the shows about 50 lines of current data out of the ECU, one day I will get around to it and examine the problem thoroughly.
Matt
Postby dotdog » Wed May 10, 2006 7:53 am
Yea mine is smillar its for about 2 or 3 minutes after the car has been sitting cold for about 5 or so hours.
Has anyone trying retarding the base timing to see if that makes it go away? cause mine is still running the facto 10 degrees
dotdog
Postby demis » Fri May 12, 2006 4:50 pm
apparently the resitance test is not that relible
demis
Postby gt20v » Sat May 27, 2006 4:15 am
i have the same prob except.it only happen from 2k to 3k rpm..after that it will jump and pull hard.........
any info from your test demis?
gt20v
Postby Chickenman » Sat May 27, 2006 6:41 am
Same thing in Alycia's car but only really noticable in the last month or so (since it got colder... duh! :lol: )
It's all good though, shouldn't really be pushing a b/t cold anyway... think of it as a reminder.
I will say, the engine sounds better off vvt at mid range rpm. Then again, we haven't spoiled the car by putting on a fart cannon.. just some pink stickers (no.. it wasn't me).
I saw someone racing his BZR last night (grey levin) after I watched him put 91 in it... don't buy that one :roll:
Baby Jesus
Chickenman
I Am The Walrus!
Postby offensive » Sat May 27, 2006 9:33 am
when my car was running with a silvertop ecu, it would hesitate, pop splutter then take off when warming up, and pretty much run really bad. Replaced the ecu with a blacktop ecu and it runs sweet now. throttle bodies were cleaned, TOM'S trumpets and plenum chamber are all thats really been changed along with ecu.
only thing that slightly bothers me now is now the weathers getting colder, it idles at nearly 2 grand in cold mornings
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Postby RAZA » Sat May 27, 2006 9:35 am
About a year ago mine was doing it, and there was a thread on here about the same thing.
Everyone seemed to be saying that cleaining the TB's fixed it for them, I cleaned mine and it fixed it on mine.
I see some of the people above have tried it and it hasn't worked for them, but if you have this problem and haven't tried cleaning your throttle bodies it might be worth giving it a go.
Currently driving:
BMW 135i M
RAZA
Postby Mr Revhead » Mon May 29, 2006 10:11 am
how many ppl having this issue are running washable filters?
Postby Lanius » Mon May 29, 2006 10:25 am
Mines running trumpets, and has the same issue. Not so much a hesitation as a bad flatspot on mine tho. Once shes warm, it completely disappears.
Lanius
Postby dotdog » Mon May 29, 2006 6:22 pm
Ive got a hks foam filter on mine
dotdog
Postby B1NZ » Mon May 29, 2006 6:40 pm
dotdog wrote:Ive got a hks foam filter on mine
snap :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby demis » Mon May 29, 2006 7:39 pm
mine is running a toyota air filter int the factory air box
the engine is completly standard
cleanded t/b twice dosent make any diffrance
demis
Users browsing this forum: Google [Bot] and 2 guests
