Wheels shaking
Postby solitaire » Fri Jun 30, 2006 3:46 pm
Not gona be relavent to you but i thought id throw it in for interests sake..
Was driving my sw20 back to work on wednesday and got viscious vibration between 80-100 (like 4 times more intense than you average unbalanced wheel)
i pull over.. no flat tire... figured it was the balancing so i start again... intending to drive to my balancing place, it happens again but even worse...
So i pull over suspecting i must have a wheel thats about to fall off... i looked at each wheel and found nothing wrong except for a little smoke coming from the right front... the caliper had seized.... (bloody turbo was pushing it along)... i touched the wheel (factory skyline mags) and it was almost too hot to touch... i hate to think what temperature my disc was... $150 later and a rebuilt caliper
AE92, KZJ120, KDJ120
solitaire
Postby Ako » Fri Jun 30, 2006 4:18 pm
It doesn't have any issues with vibration under hard accel does it?
One of my cars had a mad vibration under full throttle AND just when cruising above 90km/h. Ended up being a toast engine mount. Was something you felt more through the seat than the wheel, but nevertheless it did shake the steering wheel.
Worth a shot.
Though by the sounds of things - in his shoes, I'd be selling the car. Accident repaired car + still having issues after "repair" = bags not owning it.
Ako
Postby BZR4AGE » Fri Jun 30, 2006 8:29 pm
nope. found out wht happen finally, quite serious really, the rear drive shaft and assembly are stuffed majorly. if you put it on a hoist, and shake the back wheels, it actually moves ALOT! so my mate will try sort it out now. Cheers guys
BZR4AGE
Postby Ae92typeX » Sat Jul 01, 2006 1:12 pm
good you found out the problem, but strange it was only felt through the steering if it was tha bad...
Ae92typeX
