bluemaumau wrote:can anyone claim 13.7(i think) on a N/A 2zzge? (FLYRYD)
dont think so
I doubt it. the quickest I've read about an NA RunX/celica/XRS is 14.7 NA on street tyres.
Reaper_2000 wrote:point noted. i heard some come with a 6speed close ratio box, unsure what car or anything, but does this make much difference(if its true)?
some do, mine does(RunX), it's nice, but not what I would call necessary. it is fairly common in cars with a 2zzge(Corolla XRS/RS180/RunX/Allex/Fielder/Celica GTS, Pontiac Vibe and a few others)
This is gleamed from forums that I read or am a member of...
It is stated from Toyota that it(the 2zz-ge) is 141kw/181HP, or 190PS in Japanland.
The different versions that appear around the world have different specs.
The USDM Celica GTS is rated at 170HP due to some emmisions crap that the other countries don't get, also redline is at 7800 instead of the JDM 8000-8300.
The late 2001-2003 2zz-ges in the corollas and Celicas appear to have been programmed differently, giving better mid range torque, but only 168HP, the mid range torue clears up the dull spot before it hits lift(5500-6000).
Any more info needed, just ask, I have a heap of it.
Oh, and to compare it with B18C, in "testing" with an NZhondas forum member, we came up pretty close, I edged away at the start, he caught up to be even... not a lot in it. It was daylight, and it was on the street, so yeah, we werent trying to break any laws or anything while trying to compare.
