Progressive rate springs will help, but you will either need to compromise on the ride quality or shorten the strut body with a shorter insert to get back suspension travel.
Callum
AE85coupe wrote:cut springs are not good, but they are not horribly dangerous either.. if done correctly
likewise with compressed springs
l1ttle_d3vil wrote:AE85coupe wrote:cut springs are not good, but they are not horribly dangerous either.. if done correctly
that was my opinion; but i thought I better get some other advice before possibly making my car illegal, and so I don't "ruin for everyone else". seems that I was doing that by just asking for opinions though...![]()
cheers.
cheers.
AE85coupe wrote:just cut the bloody springs and get some good quality inserts, you can put ae92 inserts into ae85 struts, they are considerbly shorter so will keep the spring captive (you just need to put a spacer at the bttom of the ae92 shock for it to work)
