Does the TRD head gasket raise compression?
Postby Mr Revhead » Sat Jul 15, 2006 10:42 am
reading that hurt.
let alone working it out 8O
think ill just email you what i want to know and threaten you with higher prices to get what i want :P
Postby sergei » Sat Jul 15, 2006 10:58 am
"Oh NO"
Postby pc » Mon Jul 17, 2006 10:45 am
It's simple math, and necessary to work out the current CR ratio and target CR. Combining all of the equation into one line makes it look a little daunting tho.
Don't forget to include the volume of the gap between the cylinder wall and the piston, from the top ring to the top of the piston... and also the volume of the top of the cylinder if it's not flat.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Mon Jul 17, 2006 10:56 am
yeah my biggest issue is not the maths, its finding exact volumes
Postby pc » Mon Jul 17, 2006 1:00 pm
I wasn't sure on the standard way of measuring the volumes of the piston & combustion chamber, but I used plasticine.
I filled the top of the piston with plasticine, shaved it off flat using a steel rule, then rolled it into a ball and put it in a measuring beeker with water and got the volume in ml (cc) that way. The same was done for the combustion chamber (with spark plug installed), and the rest was done with calipers and a calculator.
The engine reconditioner came up with the same figures as I did, so this method seems to work ok.
red car
Manfield - 1:24s
pc
Postby sergei » Mon Jul 17, 2006 1:07 pm
to calculate the compession ration you don't need to know the voluems of combustion chamber or piston shape, because it is constant and does not vary, all of those things can be considered as "combustion chamber volume" in my equation.
Infact you could simpilfy formula and exclude stock head gasket volume from it by replacing volume difference between new gasket and old gasket (+ with increase - with decrease).
Postby pc » Mon Jul 17, 2006 4:34 pm
Ummm.... no you can't do that.
you still need to know the volume of the
combustion chamber
+ headgasket
+ piston dip thingie
+ gap around the top of the piston
To be able to add all of these things up, you will need to know what they are.
red car
Manfield - 1:24s
pc
Postby Truenotch » Mon Jul 17, 2006 7:06 pm
AE85coupe wrote:
CAMB01 wrote:45 thou or 45 thousandths of an inch is just over 1mm.
dam.. guess i've got enough compression then heh
How does your smallport go with that much compression? I'm thinking about raising mine a bit.
Truenotch
Postby sergei » Mon Jul 17, 2006 8:18 pm
pc wrote:Ummm.... no you can't do that.
combustion chamber
+ headgasket
I disagree with you. You don't need to know this. What you need to know is the change in that "static volume", wich is pretty easy - volume of new gasket minus volume of old gasket. That will give you a change. Treat rest of the volumes as one volume "x", because it is static it will not matter what it is composed of. ie Comubstion chamber stays the same, deck heigh stays the same, piston hight/depth stays the same, what only differs is the gasket thickness. So just add/subtract (depends if thicker or thinner) the difference of new gasket volume vs old to that X.
as in here:
old C.R. = ( Bore volume + X ) / X
new C.R = ( Bore volume + X + change in gasket thickness ) / ( X + change in gasket thickness )
knowing old C.R. and Bore volume, it is possible to find X - which is combined volume of comubstion chamber, deck heigh, piston dish/dome, stock gasket. etc. Then knowing X it is possible to reintroduce it in new C.R. equation and calculate new C.R.
Simple algebra.
Postby Mr Revhead » Mon Jul 17, 2006 8:29 pm
just make a spread sheet and post it up :P
Postby JT » Mon Jul 17, 2006 8:49 pm
Mr Revhead wrote:just make a spread sheet and post it up :P
I'm working on it...
Sergei, to not confuse matters ( :lol: ) best to refer to your 'bore volume' as 'swept volume'
JT
Postby sergei » Mon Jul 17, 2006 10:05 pm
Sorry about that, you know, english is not my first language :wink: :lol:
Postby AE85coupe » Mon Jul 17, 2006 10:06 pm
Goes bloody awesome, it loves it, won't run on anything but 98 mind you, and i had to retard the timing a touch (need some av gas haha)
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby pc » Tue Jul 18, 2006 10:21 am
combustion chamber
+ headgasket
as in here:
Simple algebra.
Ahhh... I see. You are assuming that the current CR is known (accurately)... I am assuming that it isn't.
red car
Manfield - 1:24s
pc
Postby JT » Tue Jul 18, 2006 11:04 am
pc wrote:Ahhh... I see. You are assuming that the current CR is known (accurately)... I am assuming that it isn't.
If you don't know your CR then you'll have to do it the long way. Assuming it is known accurately (and the standard gasket is 1.2mm) I have calculated for a 16V with 9.4:1 standard CR a 0.8mm gasket with raise compression to 9.8:1 and a 0.5mm will raise it to 10.1:1
Would be interesting to know how much a standard gasket squashes when the head is tightend in place. The calculation depends on a few variables that we have to assume are constant.
Not quite sure how Jebus arrived at his figures?
Will sort out the rest of the 4ag series and some error margins of standard CR. This assumes the head and pistons are standard but I can calculate if you've had the head skimmed.
JT
Postby TRD Man » Tue Jul 18, 2006 1:47 pm
I think you're pretty close JT. At some point we did the calculations and determined that the 0.8mm gasket raised the ratio by about 0.3 roughly.
TRD Man
Postby JT » Tue Jul 18, 2006 4:01 pm
AE85coupe wrote:hmm so when i took 45 thou off the head of my smallport how much did i raise the compression?
whats 45 thou in mm?
45 thou is 1.143 mm. If you used a standard gasket you'll have ~11.7:1
TRD Man wrote:I think you're pretty close JT. At some point we did the calculations and determined that the 0.8mm gasket raised the ratio by about 0.3 roughly.
Yeah, 0.38 to be exact :wink: But thats for a bigport. Don't forget that the standard CR of an engine determines the CR with a new gasket so a smallport will have a slightly larger increase of compression of 0.47
For a silvertop it increases by 0.49 and for blacktop 0.55
JT
Postby AE85coupe » Tue Jul 18, 2006 5:31 pm
cool 11.7:1 eh, thats awesome, surprising i can still run it on pump gas hahahaha
Details of car here
AE85coupe
