CircuitLevin wrote:RedMist, what work has Kelford done for you on your car? How did you find them at that time when developing the products for your car? Who did you work with?
My 16 valve engine was originally built by an Ex TWR engineer. It's ports dramatically reduced and then port matched to what was then a Weber manifold. I replaced the webers with silvertop TB's with a custom adaptor again mated to the inlet port face. Kelford supplied a shim under bucket solution, springs and some weld builtup L7 cams. They have performed flawlessly with no noticable wear.
Kevin is a little egotistical but I cant say I've had any issue with his product. In addition where everyone else states its almost impossible to get HP from the 20 valves his end product really produces, not only the numbers but the speed. One of which, a pretty stock 20 valve with bumped compression and a set of his cams I cant get near.
I wouldn't use Kevin for port work, not because I dont believe in his work, just I have very specific ideas on what to do to produce the torque and HP I require.
However Kevin developed the entire 16 valve of Wayne Moriarty. Although the engine produces 5bhp less than mine its appears to be a stronger engine and surprisingly still uses shim over bucket.
In December we (I and an engineer named Mark Pawsey) re-developed the engine and got an additional 10% in flow by further shaping of the port post the port choke.
The engine didnt produce the numbers we were expecting and we had (JD I think) come and time the cams for us. With a little dyno work we produced a considerably fatter torque curve and 10 additional HP over the last rebuild. He's definately worth the small cost to get a very accurate cam timing that will produce straight off the bat.
I've also talked with several of the other engineers there re my 6a10 (v6 1600cc engine) and they have surprising knoledge re an engine I thought was very rare and totally undeveloped.
