LED Taillights on AE101 Wagon
Postby bluemaumau » Wed Aug 16, 2006 7:43 pm
true that looks cool, thanks rick :D
Postby BZ Touring » Thu Aug 17, 2006 10:18 am
Interesting info about ABS shutting down. Cheers.
I'm starting to think these replacement LEDS are a bit more trouble than they're worth...bring on the consumer garauntees act!
BZ Touring
Postby johntramp » Thu Aug 17, 2006 3:38 pm
wow, so insead of going to the trouble of taking out the abs we can just replace the bulbs and not have to bother with that crap :D
johntramp
Postby Stealer Of Souls » Thu Aug 17, 2006 3:43 pm
I would think that it'll just be annoying. Any you will fail WOF as the guy will think the ABS is broken...
As for bulbs...
http://www.superbrightleds.com/1157.htm
The clustered LEDs are okay... But the luxeon 3W version is MUCH MUCH better... Unfortunately US$20 a piece. But they are marginally brighter than a standard bulb, and have much better light spread compared to the clusters...
I've got a "twin filament" park/stop one in my car. And it looks better than the standard bulbs. Just saving up to replace all the remaining bulbs.
'86 AE85.5 Levin
Stealer Of Souls
Postby AceSniper » Thu Aug 17, 2006 5:08 pm
pull the abs error codes there is a way but I cant rember make sure it is the bulbs as mine also has abs... wasnt a issue
AceSniper
Postby BZ Touring » Fri Aug 18, 2006 12:52 pm
The LED bulbs are gone for now (along with the ABS error thank goodness).
BZ Touring
Postby snwtoy » Fri Aug 18, 2006 6:45 pm
BZ Touring wrote:Interesting info about ABS shutting down. Cheers.
I seriously doubt a car manufacturer would be stupid enough to let an abs system be affected by the resistance of a lightbulb. Let's see, I've blown a tail light so I'll turn abs off? Whatever.
Does the ABS light come on when you have no bulb connected?
snwtoy
