repowered wrote:whats the role of the igf terminal on 4age ECU
on my diagram its 'igintion conformation signal', is this an input or and output?
not getting any reading out of it from multimeter in any state of igintion/cranking which im guessing is the cause of my problems.
going to try a new ECU, got one on the way that has extact same numbers as the one i currently have
matt dunn wrote:repowered wrote:whats the role of the igf terminal on 4age ECU
IGT is the signal from the ECU to the igniter to say fire,
IGF is the signal from the Igniter to the ECU to say that it has fired ok.
l1ttle_d3vil wrote:repowered wrote:any luck with this man?
never seen any pics...?? have u posted any up?
l1ttle_d3vil wrote:are you sure that yellow plug on your engine loom is for the ignitor? it should be a green plug for the ignitor (as is on the ignitor) i would've thought. have you got any other plugs hanging loose that you haven't used/don't know what they're for? like a green 2-pin plug or something?
l1ttle_d3vil wrote:
then I have got the standard + and - wires from the original ke wiring/coil going to the appropriate terminals on the coil to provide power to all of this.
l1ttle_d3vil wrote:ok ive just checked out exactly how my coil/ignitor are wired up.
i'm using a 4-pin plug for my ignitor as thats what I had available to wire it up with but im actually only using 2 wires on this plug. they are the IGT and IGF signals coming from the ecu. they go straight from the ecu, through the plug and directly into the ignitor. they are (on the ignitor side of the 4 pin plug) a pink wire, and a white wire. check that your IGT and IGF signals are connected to these corresponding wires on your wiring.
my ignitor has the following wires:
pink / white / creme / blank / black.
the first two are the igt/igf signals, the creme one is connected to the + terminal of the coil. im not sure what the next one was but i figured I didnt need it when I was doing some work so removed it. the black one is connected to the - terminal of the coil.
hope you can follow all this; check all your wiring and make sure that it is all correct as ive said above. if it isnt, try it this way and see if you get some spark.
as for the voltages of the igt and igf signals, all I can find is that IGT should be between 0.7 - 1.0v while cranking or idling.
jondee86 wrote:OK... looking in my box of spare wires, and reading the wires from
left to right looking at the end of the igniter :
1. Pink wire = IGT = Blk/Blue wire to 10-pin ECU plug
2. White wire = IGF = Blk/Yellow wire to 18-pin ECU plug
3. Light Brown wire = Common p/s to coil +ve and igniter
4. Yellow wire = Tacho output
5. Black wire = Coil -ve
Hope that helps![]()
Cheers... jondee86
