Oil Catch Can Question
Postby big_boy » Tue Jan 23, 2007 10:44 am
well in that case i would be checking the PCV
for sale EE90
big_boy
Postby Mr Revhead » Tue Jan 23, 2007 10:56 am
that wont stop the problem though, unless its jammed shut
i ran mine with both lines going into a can.
i didnt have any issues.
if you do that and have leaks then maybe its time for a rebuild.
while it wont create a negative pressure in the crank case, it wont cause much in the way of pressure either.
Postby SpeedRacer » Tue Jan 23, 2007 11:47 am
excuses my dumbness, but how do u know u've got high crankcase pressure? is it just cos u get leaks? or u oil pressure guage is high?
Sinister Sleeper 35
SpeedRacer
Postby big_boy » Tue Jan 23, 2007 11:50 am
un explaned sudden leaks indacate that there is an excess of pressur in there all of a sudden that are pushing the old seals to far witch were normaly ok when the was a vacume in there
for sale EE90
big_boy
Postby Dirtbag » Tue Jan 23, 2007 1:15 pm
http://dirtbag.no-ip.com/
this is how i set mine up. no problemos, mayb not be the best way though, not entirely sure.
ontop of that, u can run a sealed catchcan with a feed back to the intake pipe to more replicate the factory setup but with the gases being removed.
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby matt dunn » Tue Jan 23, 2007 9:17 pm
Dirtbag wrote:http://dirtbag.no-ip.com/
A sealed catch can will not remove the gasses as they are in the air and just float straight through.
It will remove the lumps, but if there are lumps in there you ,have more than vapuor problems,
And it affects anything that runs a knock sensor.
Postby frost » Wed Jan 24, 2007 10:49 pm
i know lots of guys who put a roll of steal wool in the catch can for the vapors to pass thru and filter out the grime and exit cleaner air back into the intake system hole as said above.
Users browsing this forum: Bing [Bot] and 3 guests
