blown head gasket
Postby Mike- » Wed Jan 10, 2007 10:47 pm
which bit are you looking at on the first pic?
Mike-
Postby Alex B » Wed Jan 10, 2007 10:54 pm
Has that rocker cover look about it to me.
Postby Dell'Orto » Wed Jan 10, 2007 11:15 pm
Dont worry about it, just get the next oversize piston set, get it bored to suit and slap it back together.
Postby fangsport » Thu Jan 11, 2007 7:14 am
guys, it's a 4K. unless it's had plenty of other work done to it either buy another motor or hone and re-ring it. by the time you rebore and get pistons you my as well get bearings etc , which will all add up. chances are you might get away with just a head gasket, but it will more than likely be smokey.
where abouts are you Mike? have a few short blocks here if you wanted to swap the bottom end.
fangsport
Postby Mike- » Thu Jan 11, 2007 3:31 pm
to clean out the cooling system, can i just squirt a hose down the holes on the right side of the block, ill cover up all the others holes and cylinders first.
Mike-
