Turboing my Celica???
Postby Boosted_162 » Wed Apr 04, 2007 2:02 pm
Infinite wrote:the lsd box come in the superstrut, so if his isnt superstrut it wont fit
A mate of mine bolted a ST202 LSD box into 3SGTE-powered ST182. So either they do bolt in, or some do come in non-superstruts.
Postby Infinite » Wed Apr 04, 2007 7:41 pm
superstrut has a different subframe and the rear mount bolt's are about 30mm's different on a st202 non ss i should know ive gone down the track of having multiple subframes compared and messured.
Lots
Infinite
Postby sergei » Thu Apr 05, 2007 10:03 am
A simple thing:
have you guys tried to unbolt mount bracket and bolt your bracket?
This is what I had to do to fit ST205 g/box into ST165.
As I would think that bolt pattern on gearbox should be the same.
Postby bluemaumau » Thu Apr 05, 2007 11:30 am
as sergie said , its pretty easy to get it to fit just $&#$% around with subframes, brackets, mounts etc, cant be that hard if its the same family of engine /gbox
Postby Infinite » Fri Apr 06, 2007 5:44 pm
ive tryed both sets of mounts, and it dont work. if some one would like to prove me wrong u could come fit it with a st202 mounts or the st206 mounts if u like? be my guest
Lots
Infinite
Postby bluemaumau » Fri Apr 06, 2007 6:37 pm
have you tried the raer mounting brackets of both gearboxs?
