haw haw haw!
TRD_ZERO wrote:OK this may help or maynot.
I had just got my car sorted and left to got to newyears about halfway there my car started sounding like a tractor really loud, almost like the exhaust had fallen off or there was a blown exhaust gasket. I pulled over at the local gassy and checked it out i just guessed the wastegate was jammed open. I did another thousand kms before i got it checked out and what ended up happening was the compressor housing started falling off the exhaust housing as 2 of the four bolts had fallen out.
It also felt sluggish......... i think you should take it to an exhaust shop and see if they can tell you where the noise is comming from, get that sorted and see if the problem persists.
avinesh wrote: he did the whole 3inch mandrel system on my car with flexi for 350 doller.....
Al wrote:avinesh wrote: he did the whole 3inch mandrel system on my car with flexi for 350 doller.....
I'd be pissed if you got charged more! Mine was $300 with an adaptor flange made up + $50 for the flexi I bought elsewhere because Magoos told me they were $200+gst
