Instructions for replacing Blacktop 4AGE big end bearings
Postby Mr Revhead » Fri Jul 13, 2007 8:22 pm
no its not one size fits all
mate in all seriosuness....
i think your biting off more than you can chew....
first things first:
do you have a mate/relative/bitch/pet that has done it before?
sucsessfully?
if not.... then i really do think its best you save untill you can fix it correctly
sorry to rain on your parade, but you do seem very much out of your depth here, and the pontential do destroy the engine (if its not already dead) is very high.
fyi if you have been running it for any length of time, its very likely its already damaged too much.
Postby Timoz » Fri Jul 13, 2007 9:19 pm
hey Rev what can i do to fix it if it had been damage already? and how much around to fix it up probably?
Timoz
Postby slighty_sykotic » Fri Jul 13, 2007 11:15 pm
Timoz wrote:hey Rev what can i do to fix it if it had been damage already? and how much around to fix it up probably?
Are you reading?
If its the bearings you need to do this:
Take sump off,
undo big end caps, replace the bearings.
Put caps and sump back on.
Sounds simple doesnt it...
Expect the fact that you WILL have damaged the crank because you are still running it.
So you will need to take sump off, take front pulleys etc off, remove gearbox and flywheel and crap, then take off the big end and the main caps, then lift out the crank. Go get the crank ground, reassemble with the right size bearings and lube, and put it all back together.
AGAIN! If you have to ask, you can't do it. Unless you have someone to show you how.
--Sykotic
slighty_sykotic
Postby Timoz » Fri Jul 13, 2007 11:33 pm
if i need to do all these how much approximately if i take it to a mechanic to do it?
Timoz
Postby Grrrrrrr! » Sat Jul 14, 2007 12:08 am
If he needs to take the crank out and get it reground i wouldn't be expecting change from $1000 as he will basically have to pull the motor and box from the car, crack it open, remove the crank, get it ground, replace it and fit all the new stuff. (you may as well do the cambelt, waterpump & tensioners at the same time, the parts cost isn't huge and will save you a big labour bill later)
The first thing you need to do is to get an accurate diagnosis because from what i can see you are still just guessing as to what the problem is. No point going out buying parts until you know what the problem is. Trust me on this, i ordered a couple hundred $$ of parts of revhead while i was in Oz based on a diagnosis of a blown head gasket by the mate that was borrowing my car at the time.. pity it was only a leaky hose.
Grrrrrrr!
Postby Timoz » Sat Jul 14, 2007 12:18 am
ok i think i'd better get a mechanic to check it up fully, i rather spend a pre-repair money rather than guessing around than. thanks man
Timoz
Postby Ae92typeX » Sat Jul 14, 2007 9:12 am
lol, I asked you if you had done that a day ago and you didnt answer.
ask them for a quote while you are there...beats getting an internet estimate when no-one can actually see/hear it to estimate imo.
Ae92typeX
Postby Timoz » Sat Jul 14, 2007 12:29 pm
i just took it to toyota today and the mechanic said its the clearence of the bucket and shims so i just book a clearance check to see wat happens
Timoz
Postby Mr Revhead » Sat Jul 14, 2007 12:33 pm
ok, so its more a loud ticking?
sounds a lot nicer than run bearing.
when you drop it off, make damn sure you ask for a roundabout price....
if they are going to redo all the clearances you may face a little more of a bill than you first expect
Postby Timoz » Sat Jul 14, 2007 3:30 pm
they said $190 for a clearence check but they dunno how much to fix it as they haven't done one before.....so i dunno aye hey rev do u know the prices for the shims for an AE111 4AGE Blacktop?
Timoz
Postby Mr Revhead » Sat Jul 14, 2007 7:28 pm
sweet.
um, around $10 each top of my head
Postby ChaosAD » Sat Jul 14, 2007 7:32 pm
But are they under bucket type shims? can they be done without removing the cams?
ChaosAD
Postby Mr Revhead » Sat Jul 14, 2007 7:35 pm
nope
but they can check them
Postby Timoz » Sat Jul 14, 2007 7:46 pm
so most of the cost of this repair is the labour as the parts are cheap ass, does anyone know how long it would take? to check, replace(if needed)? And they have to take my cambelt and cam pullies off to take off the cam shafts than check the clearences?
Timoz
Postby matt dunn » Sun Jul 15, 2007 10:03 pm
Just to check them and see if they are out is only 1/2 to 3/4 hour at the most.
If you've done enough and know what your doing it can be done in a bit less.
Just need to remove the spark plug cover, remove the HT leads, undo the three 12mm nuts and unplug the two hoses so the cam cover comes off.
Turn to TDC and check them, Turn tio TDC again and check the other one's,
Then re-assemble.
Piece of cake. but to measure them you need a good set of feeler blades and to know the feel of what's tight and what's loose, not something that can be explained.
Postby try_hard » Sun Sep 02, 2007 4:00 pm
can anyone suggest any ways to remove the timing belt gear on the crank. the one with the theath of course. its on the silvertop and this guide dosnt help as the cover is diffrent and no way can i fit 2 screwdrivers behind it.
AE92 Trueno Sprinter 4AGZE
try_hard
Postby Ae92typeX » Sun Sep 02, 2007 6:03 pm
Buy, borrow or make a puller.
1st 2 prob best option, but making one is fairly easy for the able tooled.
Ae92typeX
Postby try_hard » Sun Sep 02, 2007 8:11 pm
i have a gear puller. it was fine to get the big ones off the crank but the little one behind it for the timing belt is very hard to get at and the puller cant get in the gap of the cover.
try_hard
Postby AceSniper » Sun Sep 02, 2007 8:29 pm
put some oil on the crank nose, try and leaver it off with screwdrivers, you might be able to get hold of a puller with thinner legs that will get behind it?
AceSniper
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
