need help with quad throttle body information!!
Postby I TRD I » Sat Sep 08, 2007 8:08 am
Im pretty sure running the quads is sweet on your factory ecu , you just need to run the MAP sensor off a vacum tank that is supplied from each ITB . it also helps to have a dampener valve just before MAP sensor.
NZ new AE82 GT sedan I TRD I was stolen in january still nothing recovered ! I TRD I is now a notchback ae85 with full ae86 running gear , high comp pistons , hks cams , etc
I TRD I
