Piston Slap?
Postby CAMB01 » Wed Jan 09, 2008 7:02 pm
piston slap is caused by having excess clearance in the bores, either by having worn bores, or collapsed piston skirts, or having forged pistons which require a lot more piston to bore clearance, due to the expansion rates. (Or you own a Subaru)
The skirt of the piston hits the side of the bore on the power stroke, as the piston is on the way down after ignition.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby ChaosAD » Thu Jan 10, 2008 12:56 am
Just to swerve off topic a bit. Ive heard a lot of rattley subaru's, always thought it was the bigends or something else bot to fuk ot. Why the fuk are they so rattley??
ChaosAD
Postby matt dunn » Thu Jan 10, 2008 3:25 am
ChaosAD wrote:Just to swerve off topic a bit. Ive heard a lot of rattley subaru's, always thought it was the bigends or something else bot to fuk ot. Why the fuk are they so rattley??
From what I hear about the Sub's, it the lifters in the head,
which when they get bad enough means new heads are required.
Postby Lloyd » Thu Jan 10, 2008 7:23 am
Having said that they never seem to acctually break, just get horribly noisy
Postby Mr Revhead » Thu Jan 10, 2008 8:13 am
REALLY REALLY Noisy.
8O
