St215 Making a rattling noise
Postby thedrunkfish » Mon Mar 03, 2008 4:44 pm
oh maybe not 150 just wanna know if anyone can get them at a better price basically. toyota quoted 300, others 270 odd.
thedrunkfish
Postby thedrunkfish » Fri Mar 07, 2008 3:41 pm
problem identified today by a different mechanic as FR wheel bearing, being replaced with toyota part today, im gonna be pissed if the noise aint gone.
thedrunkfish
Postby thedrunkfish » Fri Mar 07, 2008 5:15 pm
wasnt the FR bearing. Mother%^$^%$^ guess next stop is FL.
thedrunkfish
Postby gttNICK » Mon Mar 10, 2008 11:02 am
Mine definately sounds like it comes from left side. Are you getting FL done too?
Caldina gt-t
gttNICK
Postby 99gtt » Mon Mar 10, 2008 8:54 pm
are you sure its not your exhaust banging , hop under the car and wobble your exhaust from side to side in different places and see if it bangs . i know of 4 other people, who had been told wheel bearing but in the end it was the exhaust rattling and only at certain rpm . Mine was the exhaust, and i got told everything from hanger bearing to wheel bearing.
SOON TO BE 500 HP
99gtt
Postby gttNICK » Mon Mar 10, 2008 9:38 pm
yeah definately not that, had that problem when I had the exhaust done and was sorted out. And that would flex under load and hit something, my noise is under decelleration
Caldina gt-t
gttNICK
Postby Santa'sBoostinSleigh » Tue Mar 11, 2008 1:11 pm
my LR wheel bearing went ages ago
also i had a knocking noise, worse in wet, worse when turning left from memory, under accelleration - was driveshaft hitting exhaust
check your exhaust manifold heat shield has the bolts done up tight - ive seen that making noises before
also check to see if youve got a pod filter/bov/amp fuse etc knocking around in the engine bay somewhere (also check its not hitting/rubbing on the bonnet when its closed)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby gttNICK » Tue Mar 11, 2008 4:40 pm
I have all of those things but the noise follows engine rpm exactly so not so sure it would be
Caldina gt-t
gttNICK
Postby thedrunkfish » Tue Mar 11, 2008 5:14 pm
i had it checked at pit stop, def not exhaust they said. Got it up on hoist and couldnt replicated the noise under deceleration, definately sounds like it's coming from te front left. It is either gonna be the wheel bearing or an inner cv. i can only hear it under deceleration but cant hear it until the car has warmed up a bit like 3 or 4 minutes. im selling mine and it's going in for an aa check. All the mechanics that have checked it (4 now) all said that if i didnt tell them about the noise they probably never would have heard it as it is quite faint. But it does go away if i turn even slightly to the right or i put the clutch in. Im convinced from what i have read it's FL wheel bearing and i have told the dude all about it. so well see what aa says tommorrow
thedrunkfish
Postby thedrunkfish » Mon Mar 17, 2008 6:11 pm
oh by the way nothing showed up at all about it on the aa report, car now sold.
thedrunkfish
Postby bbq1988 » Thu Jul 17, 2008 12:36 pm
Sorry to drag up a old thread but my wagon is making funny noises that maybe related to this.
Its only noticable on super smooth roads (i.e hotmix) and at 30-50km/h
It sounds like a toned down version of when you drive on those small bump/ripple strips that you occasionaly find on corners (kaimai's are a good one if you know what im talking about?)
idea's? im going to check if anythings rubbing this weekend. i know it rubs on full lock and my suspension is stuffed.
Baked, Not Fried.
bbq1988
Postby thedrunkfish » Thu Jul 17, 2008 12:50 pm
the guy i sold it to told me the noise went away after replacement of fl wheel bearing
thedrunkfish
Postby snwtoy » Thu Jul 17, 2008 3:25 pm
Mr.Phreak wrote:150 is horrendous?? :?
Charade wheel bearings = $40 a pair. (not inc labour). Depends on the type of bearing though.
snwtoy
Postby bbq1988 » Thu Jul 17, 2008 4:02 pm
Price from toyota (inc discount) is $195+gst for each front, $395+gst for each rear... i'd be happy to own a charade at this point!
Baked, Not Fried.
bbq1988
Postby sergei » Thu Jul 17, 2008 4:19 pm
I can't be bothered reading the whole thread but noise could be gear back lash on manual transmission.
My ST165 does it (ST205 g/box), it is due to clutch with heavier centre springs.
Also very common with solid clutches/multi-plate clutches.
It would come as a rattle (similar to say a loose heat shield but slightly lower pitch), when decelerating in the gear. Press in the clutch noise goes away.
A lot of rally cars do that as well (obviously why).
Sometimes it could be heard in neutral while car is idling, if you press the gear stick gently into a gear but not engaging the clutch and not engaging the gear, the noise will go away while the synchros are preloaded.
