QQ: Cheap/easy/legit way to lower ee80 4dr hatch?
Postby tsoob » Sun Mar 23, 2008 7:31 pm
lowering spirngs for this car would cost around $350
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby cr1mnl » Sun Mar 23, 2008 9:08 pm
Scotty wrote:
cr1mnl wrote:
slighty_sykotic wrote:
evil_si wrote:cut 2/3 coils and have the struts shortened to keep springs captive,
Better than compressed springs and legal
Dont talk bullshit.
Its not legal. This is how sh*t gets spread around. IT IS ILLEGAL TO CUT SPRINGS!!!
not its no illegal if you do it properly. I've had cars certed with shortend struts and springs aswell.
and just like that you are wrong
read my post again. IF DONE PROPERLY. ie certified
i'm not saying go cut your springs. just stating that if done properly can be legal and certified
going by your post that also means coilovers are illegal aswell which they are if they aren't certified. however if done properly and certed they are legal
so just like that you are wrong
www.ology.co.nz
cr1mnl
Postby Mr.Phreak » Sun Mar 23, 2008 10:24 pm
Either way, anything involving certification doesn't fit the OP's question so it's not really valid
Mr.Phreak
Postby cr1mnl » Sun Mar 23, 2008 10:47 pm
true that. How about just getting the struts machined down say 30mm. This will get the car slightly lower and stiffen up the suspension somewhat. Not sure if its legal without a cert or not though.
www.ology.co.nz
cr1mnl
Postby 85AW20v » Sun Mar 23, 2008 10:55 pm
And if they are the original springs? A good lawyer could probably have a lot of fun with that one - if you had the money.
See ya
Simon
85 MR2 20v
85AW20v
Postby cr1mnl » Mon Mar 24, 2008 7:57 am
yeah leave the springs standard. just machine 30 or 40 mm off the top off the insert where the insert goes through the top hat. as long as the car doesn't go lower than 100mm, suspension still retains sufficient travel etc etc
or if the budget allows replace the insert with a direct bolt in replacement that has a shorter stroke
www.ology.co.nz
cr1mnl
Postby Scotty » Tue Mar 25, 2008 2:33 pm
Dont talk bullshit.
But what is the point of doing something half assed when it costs the same or more to do it properly :?, the guy was asking for a cheap way to do it anyways.
Scotty
Users browsing this forum: Bing [Bot] and 143 guests
