good bloody point
that could mean that even though the experiment may be a success(in that it actually works) it may be unusable for normal road going car.
RedMist wrote:A couple of things you may not have thought of.
You loose almost all of your engine braking as the throttle is open.
You loose brake assist, as you are no longer pulling a vacume when off throttle.
You loose vacume assisted steering.
So change gear, throttle off and you have to work harder to steer or brake. Not really acceptable in any car.. but tollerable in a rally car.
matt dunn wrote:How do you plan on keeping the heat from the exhaust radiating back through the sysytem and melting anything rubber or plastic on the intake?
