Yeap, good advice. Did all of those things too.
My engine bearings lasted 600klm from new.
Oil pressure is your friend - so too are good engine builders.
HRT wrote:After building a motor you should turn it over on the starter with no plugs in to build up oil pressure anyway
evil_si wrote:clean everything, dont use lint rags to wipe parts as bits stick to them
escortman wrote:HRT wrote:After building a motor you should turn it over on the starter with no plugs in to build up oil pressure anyway
i never did that after building mine, builder just said on 1st start up rev it up and float between 2000-3500rpm for ten then just start driving
gtpornstar wrote:true, thats a new one ... know who sells these ?
IH8TEC wrote:escortman wrote:HRT wrote:After building a motor you should turn it over on the starter with no plugs in to build up oil pressure anyway
and the turbo bearings run dry for a bit at a higher speed than if you were cranking it with the starter motor. hmm.
each to their own - just like with "run-in procedures kms etc etc"
