Fuel Pump ST185 ( comeone auto sparky skill ppl )
Postby Adydas » Sun Jun 29, 2008 11:37 pm
Ok back to my orignial question, does anyone know the layout of the factory fuses etc in the fuel pump system for a stock st185, while im not running a stock ecu etc my ecu has been where required spliced into the stock loom so any stock fuses etc will still be in place.
I know theres a relay in the front of the car, Anything else?
Adydas
Postby JustinSpiderholden » Mon Jun 30, 2008 8:53 am
You have spent alot of money on your car, why did you skimp out on a second hand fuel pump?
JustinSpiderholden
Postby Adydas » Mon Jun 30, 2008 6:13 pm
Im sorry i wasnt aware that i asked for a leacture, i thought i asked for advise on wiring..
And based on my above re question on the wiring its beacuse i need to track the issue as the pump is NOT failing..
Adydas
Postby Lloyd » Mon Jun 30, 2008 6:16 pm
Adydas wrote:Anyone now know how to remove a fuel tank and pump from a ST185?
HRT wrote:Undo the screws and lift the pump out
Postby sergei » Mon Jun 30, 2008 6:38 pm
If ST185 is the same as ST165 you need to drop down the tank which is held by 2 metal straps and obviously don't forget to disconnect all the hoses going to it...
