Car suddenly wont start
Postby FXGTV » Fri May 01, 2009 1:53 pm
AFM all the way
1988 r31 TI Skyline.
FXGTV
Postby Twolitre » Fri May 01, 2009 3:44 pm
Could try another ignitor if all else fails. Had a failed ignitor on a mitsi which meant the car would not start due to no spark.
You haven't told us whether or not you're getting a spark or not yet though.
Twolitre
Postby DriftSpecStarlet » Fri May 01, 2009 7:29 pm
Swapped ECU, Same problem, Check spark plugs and 2 of them had snapped off somehome? Like all the Porcelein had come clean off the plug, Swapped those out, Now its back to starting Roughly and going Bap bop bap bop bap for 2 seconds then cutting itself out... Hmmm..... Take it to the dump eh :P
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby Rob » Fri May 01, 2009 8:17 pm
Test the Opening circuit relay. That is the one bolted to the ECU bracket.
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Eddy1612 » Fri May 01, 2009 10:57 pm
Im thinking afm too. Can't rule it out. If i pull the AFM off my mr2 it will start then die straight away.
If it isnt the afm or you can somehow rule it out go to plugs if not that then try disconnecting 02 sensor, then maybe do compression check that might tell you something, then check all your leads are firmly plugged into everything.
Then if not that you may have a major vac leak, check bov? and listen for escaping air. Maybe a plug has come out somewhere also. Check fuses. Have you got enough gas in it?
Dont take it to the dump that sounds like a waste
Eddy1612
Postby DriftSpecStarlet » Sat May 02, 2009 3:00 pm
Dammit have tried all that, new AFM, still just starting and not staying on.... like its sweet and it starts up then turns itself off
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby l1ttle_d3vil » Sun May 03, 2009 12:19 pm
DriftSpecStarlet wrote:Check spark plugs and 2 of them had snapped off somehome? Like all the Porcelein had come clean off the plug,
I had a similar thing happen to one of my plugs once, except it was only cracked. would missfire until 4500rpm then haul ass, was fun to drive as I had to rev it out :lol:
still drove perfect over 4500rpm though...
Postby Lloyd » Sun May 03, 2009 12:24 pm
So what did the plugs actually look like when you pulled them out? Wet, black, etc etc
Postby DriftSpecStarlet » Sun May 03, 2009 5:04 pm
Black stuck in some new ones though
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby DriftSpecStarlet » Sun May 03, 2009 5:19 pm
Hmm... thing is it starts up fine... Idles fine... Just REALLY need to know what would cause it to just STOP itself... Actually when i was driving it home last every 5 - 6 seconds the cars power would flick on and off real quick, like the speedo and tacho would drop and car would turn off then it would flick back on........
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby 85AW20v » Mon May 04, 2009 10:08 pm
Check the earth wire on the AFM - could be broken or disconnected. Had the same sort of problem when wiring the silvertop into my AW. Think it's white with a black trace - for a silvertop anyway.
See ya
Simon
85 MR2 20v
85AW20v
Postby DriftSpecStarlet » Mon May 04, 2009 10:34 pm
Ahhhh i see that it is dodgely wired up... Are there only supposed to be four wires? as i see the plug has like 8 points lol...
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby DriftSpecStarlet » Sat May 09, 2009 3:20 pm
Back to the Top.......
Okay so today new Igniter, coil and AFM arrived, swapped parts over, same problem, Back to cranking with NO SPARK, Popped dizzy cap off and there was no moisture gave connectors a good clean too, Even tried a tow start and still no Bang
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby DriftSpecStarlet » Sat May 09, 2009 7:22 pm
$&#$%.... Took out the plugs left them to the leads and got a shit load of spark, plus gas..... It fired up once and was sweet didnt turn off after 2 seconds but that was it.... something i have noticed is the Tacho has stopped moving when cranking... ya known usually it bounces dont it? even when tow starting it wasnt moving speedo was though
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
