Where to buy braided brake lines for AE92 FXGT?
Postby Santa'sBoostinSleigh » Tue Nov 03, 2009 4:27 pm
BZG|Bling wrote:http://proxy.org/cgi_proxies.shtml
Work might not appreciate you getting around the filters (if it works) however
:lol:
nope:
Remote Proxies
Restricted Access
The web page you tried to open contains material that contravenes the council's Acceptable Usage Policy.
If you believe we have made an error in restricting this web page, please contact the IT Service Desk by phoning 444.
Thank you.
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Bling » Tue Nov 03, 2009 5:11 pm
hahahah, ok so they are on the ball :lol:
Possible for it to still work if you can find a random proxy site thats not on their list. Ask Sergei, i'm sure he will know a couple 8)
I wonder if they log users that access known work around sites.... :lol:
Postby B1NZ » Tue Nov 03, 2009 5:50 pm
Thanks, I am already watching the ones on TM but wanted an idea on other suppliers so I know if they are good deal or not as I have no idea what these retail for?
Can anyone give an idea on prices and brands/quality through various suppliers?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby pc » Tue Nov 03, 2009 6:05 pm
I would think $200 - $250 should cover it. I would recommend buying from a local supplier as I had no end of trouble sorting replacements after recieving my Goodridge lines with some random fitting on the ends.
I didn't notice any difference between braided & stock lines either... so unless gravel rash is a major concern (it shouldn't really be a problem) I would recommend putting the money into good pads, replacement fluid, and a master cylinder stopper.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby B1NZ » Tue Nov 03, 2009 6:10 pm
pc wrote:I would think $200 - $250 should cover it. I would recommend buying from a local supplier as I had no end of trouble sorting replacements after recieving my Goodridge lines with some random fitting on the ends.
Rally regs require either braided brake lines or protection of factory lines, so yeah it is for gravel.
Subaru GF8 Wagon
B1NZ
Postby pc » Tue Nov 03, 2009 6:41 pm
B1NZ wrote:Rally regs require either braided brake lines or protection of factory lines, so yeah it is for gravel.
This section? Schedule A 7.1
External lines and cables shall be protected from damage (stones, corrosion, mechanical breakages, body flex etc.)
I always interpreted this to mean that you had to leave on the plastic covers that cover the lines that run down the vehicle near the sills. Flexible lines in the factory position are not really exposed to stone damage because of where they are... The wording of the rule is not terribly specific, it also doesn't say that braided lines require no additional protection.
red car
Manfield - 1:24s
pc
Postby Alex B » Tue Nov 03, 2009 7:47 pm
:lol:
nope:
Remote Proxies
Restricted Access
Thank you.
You know thats most likley being logged by the admins right?
Postby neo » Wed Nov 04, 2009 11:47 am
Isnt it a case of at a minimum you cover them with good old plastic conduit and afew zip ties.. So should a lovely sharp rock fly up to the flexable hose it has less chance of slicing it?
neo
Postby Mr Revhead » Wed Nov 04, 2009 11:50 am
that's the minium I would do for a rally car
rocks and stuff get EVERYWHERE
Postby Loudtoy » Wed Nov 04, 2009 7:21 pm
Although mine has the standard lines, apart from where they are internal, and thats done a fair few events on gravel, in fact i can count 4 seal events in the log book and i've got one spare page left. Never been sliced or cut or damaged yet. Also never been pulled up at scrutineering with them. I read it as the factory ones are ok because from factory they have the outer covering over the line that the fluid runs through, so has covering.
PS Think those braided ones on trade me are a worker from proparts getting them cheap on his work account then selling them off. I could be wrong however
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby TRD Man » Wed Nov 04, 2009 10:18 pm
No, it means that you should cover the standard lines with a protective covering to prevent stone damage.
TRD Man
Postby Loudtoy » Thu Nov 05, 2009 7:13 am
TRD Man wrote:No, it means that you should cover the standard lines with a protective covering to prevent stone damage.
Got me thinking about mine and i know you'l be the man to answer the question. Do the standard lines with there standard outer protection meet these requirements or do they need something else over top of them
TS Member sine 2001
Loudtoy
Postby TRD Man » Thu Nov 05, 2009 9:43 am
The short answer is that they need additional protection. For the flexible lines that run to the caliper most people spiral cut some plastic hose to wind over them and tape at each end.
For the lines that run under the body and are supported by the bolt on plastic cover you've got a couple of options.
Personally, I always run these inside the car but if you don't want to do that the standard cover would probably meet the regulation however I would add some other protective membrane inside the cover to prvent stones getting through the holes these usually have in them.
TRD Man
Postby pc » Thu Nov 05, 2009 5:37 pm
standard lines... so braided doesnt need protective covering? Is braided assumed to be the protective covering?
red car
Manfield - 1:24s
pc
Postby TRD Man » Thu Nov 05, 2009 6:38 pm
Yes, braided is protected. Although some people still cover these with hose. Your choice.
TRD Man
Postby B1NZ » Thu Nov 05, 2009 7:08 pm
TRD Man wrote:Racetech are Goodridge agents. Why not drop in & see what they've got?
its being able to get there during the week, they are not open on weekends and dont seem helpful when it comes to buying things, might go and see mclennans or ABC/Mossrax then, maybe even road and track?
Subaru GF8 Wagon
B1NZ
Postby GOLDAE86 » Fri Nov 06, 2009 11:05 pm
well if ya got me to get them for ya id get em cheaper for you. But it seems like talking to a brick wall all the time. Ive offer to help ya all the time?????
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby B1NZ » Sat Nov 07, 2009 8:59 am
GOLDAE86 wrote:well if ya got me to get them for ya id get em cheaper for you. But it seems like talking to a brick wall all the time. Ive offer to help ya all the time?????
when was the last time I saw you hong kong fui? :P :lol:
Subaru GF8 Wagon
B1NZ
Postby GOLDAE86 » Sat Nov 07, 2009 10:31 am
ya dont have to see me hong kong fui!!!! ya got me number!!!
GOLDAE86
Real Life Mechanic
Postby Mr Revhead » Sat Nov 07, 2009 10:32 am
GET A ROOM!
