dnalunchie wrote:MrOizo wrote:Jebus wrote:You have a good intercooler and exhaust just run 17psi and enjoy the extra power, $&#$% doing mods to make power then adding a restrictor plate to remove the power.
Putting it like that makes it sound like wiping your buttocks before taking a shiit - Makes sense though!
I have this same problem. When i took mine in for the exhaust after the conversion without front pipe it would cut fast and hard!
Now with the exhaust i have (3.25" down pipe then to 3") it goes up to 1bar, sits there and while building revs, it cuts. Always forget to feather the throttle instead WOT
would a Fuel cut defender not correct that problem or are you concerned with it going over 15psi?
ezy10s says it will sort it out - looked at using the diode trick but at this stage i'll wait. no biggie for me at the moment.
