GA70 Suspension and brake Upgrade:
Postby deaf_rattle » Sun Dec 20, 2009 10:54 pm
cat007 wrote:Nah I was either running motul rbf600 or the penrite sin stuff. Which are both compatible to each other
it was the overheating of the rotor then pad which caused the failure. Hence why I'm sorting brake ducting before the next event :)
i thought it was the weight you were carrying... :lol:
Postby cat007 » Mon Dec 21, 2009 1:59 pm
hahahah - yeah yeah!
Altho I did take out the fibreglass sub box + amps and false floor etc out of the boot. that lot weighs in at about 100kg lol
Postby 2jayzgte » Tue Dec 22, 2009 9:19 am
Quint wrote:
blackmk3 wrote:It depends on how much "track use" your going to see and how hard it will be, standard face-lift brakes with a mintex 1166 compound might be enough? im sure Cat007 (aka Hunt) will chime in with his input as im pretty sure he ran these on his supra with face-lift brakes
Might be worth a shot. 4 pots on 323mm is probably a bit excessive, i'm starting at a pretty low level, My engine is a pretty standard 1G, with just the basic mods to max out the standard ecu and get rid of some of its lag so ~240hp at the best (will dyno it once its actually running). Nice starting point to work on 'driving' and get some good quality seat time, increase my skill and then look at upgrading the motor again. Hoping to put a package together that will out perform the motor so when i upgrade i can still run the same set up with maybe a few further tweaks.
Sounds like bilstiens with face lift hubs, upgraded pads and whiteline sway bars will be a good setup to look into.
Having those Supra 4-pots will be a blessing the stopping power they pocess is near on unsurpassed for a stock calliper that is near on 15 years old I would suggest this as an upgrade over anything you do in the motor.I'll almost say now once you have this brake set-up in place you won't touch your brake set-up again.Also they can be had brand new out of Toyota for cheap.$1 K will get you the front 323mm rotors and 4-pot Supra front callipers and trust me before I went to the TRD Monoblocks I absolutely beat up on these 4-pots for about 5 years worth of track-days and I didn't have any such issues with fade or stopping from 200 plus at anytime.If you ask me its money really worth spending.
2jayzgte
