Not firing?? No Spark....Now I have spark!
Postby AceSniper » Thu Jan 21, 2010 7:03 pm
G2 doesn't need to be wired its just the same signal as g1 but at a different crank position
G- needs to be grounded,
Both below wires are ground and best used for g-
trig 1 cable brown wire
or
trig 2 cable green wire
AceSniper
Postby TRD_ZERO » Thu Jan 21, 2010 8:50 pm
AceSniper wrote:trig 1 cable brown wire
or
So ur saying trig1 should be a brown wire and trig 2 a green wire?
What are they on the ecu pinout?
I grounded g2 and g-.
Im now getting rpms when cranking but still no spark from the coil.
Are the two trig wires i mentioned that i wired up earlier incorrect?
Previous:
TRD_ZERO
Postby matt dunn » Thu Jan 21, 2010 11:17 pm
Postby TRD_ZERO » Fri Jan 22, 2010 6:50 am
when looking at that picture it looks like i have to make trigger 1 my black wire and trigger 2 my green wire. Am i right? Cause when i look at my dizzy plug the colours from top to bottom are.
Black
Red
Green
White
Previous:
TRD_ZERO
Postby AceSniper » Fri Jan 22, 2010 5:32 pm
the two trig wires are right I think, the two wires I said above are grounded so you can wire one of them to G- (ground through ecu)
Don't ground g2 (it shouldnt matter though)
Hows your igniter wired.....
AceSniper
Postby TRD_ZERO » Sun Jan 24, 2010 1:57 pm
But on the pic that matt dunn posted its the first and third wire on the dizzy that are the triggers and i have the first and second ones wired up. So which one is correct , the picture ore the way ive done it?
Ill check the igniter tonight and let you know what ive wired up where.
Previous:
TRD_ZERO
Postby TRD_ZERO » Sun Jan 24, 2010 5:43 pm
Ive hooked the igniter up like so:
IGT= yellow/green wire hooked up to ign1 to the link which is a blue wire.
Correct?
Previous:
TRD_ZERO
Postby gasman » Sun Jan 24, 2010 7:37 pm
yea sounds right
"What can possibly go wrong?"
gasman
Postby TRD_ZERO » Sun Jan 24, 2010 8:31 pm
So how come im not getting spark?
Previous:
TRD_ZERO
Postby gasman » Sun Jan 24, 2010 8:50 pm
u sure you got a good ignitor and coil? i got a spare blacktop coild and ignitor that you could buy off me if you want. you tried swapping dizzys also?
gasman
Postby gasman » Sun Jan 24, 2010 8:59 pm
ive just checked my dizzy plug and its goes
black
red
greed
white
and according to my nots i got black as trig 1, red as trig 2 and G- and G2 grounded.
could alwas try swapping trig 1 for 2 and vise versa like cogent suggested.
gasman
Postby TRD_ZERO » Sun Jan 24, 2010 10:40 pm
I drove my car into the garage working perfectly then removed the motor. I dont see how the coil or igniter would be busted or even the dizzy as they were all working perfectly when engine was removed.
Ill give the swapping the triggers around a go tomorrow and see what happens.
Previous:
TRD_ZERO
Postby gasman » Sun Jan 24, 2010 10:54 pm
TRD_ZERO wrote:I drove my car into the garage working perfectly then removed the motor. I dont see how the coil or igniter would be busted or even the dizzy as they were all working perfectly when engine was removed.
same thing happened to me but when i went to get it tuned the dizzy want putting out a clean signal to the ecu and had to swap it.
gasman
Postby TRD_ZERO » Sun Jan 24, 2010 11:21 pm
How do i test if the dizzy is bung?
Previous:
TRD_ZERO
Postby TRD_ZERO » Mon Jan 25, 2010 7:01 pm
1:I swapped the two triggers around and no spark
2: i made the green wire trig two and the black wire trig one like shown in the pic matt dunn posted (what does n/c mean though) earthed the white and left the red, still no spark.
Previous:
TRD_ZERO
Postby TRD_ZERO » Wed Jan 27, 2010 7:32 pm
Any ideas on what i can try next? Anyone wanna help?
Previous:
TRD_ZERO
Postby gasman » Wed Jan 27, 2010 9:23 pm
is the tirgger wiring shielded and is that shielding grounded?
have you checked to see if the link ecu is putting out a trigger signal to the igniter?
gasman
Postby TRD_ZERO » Wed Jan 27, 2010 9:30 pm
Sheilded? I just wired the IGT= yellow/green wire hooked up to ign1 to the link which is a blue wire. No grounding or anything els just connected the two wires.
How do i check if the link is sending the igniter a signal? Step by step info would be awesome same with the sheilding too please.
Previous:
TRD_ZERO
Postby matt dunn » Wed Jan 27, 2010 10:23 pm
Unplug the ecu and put it in the back seat.
Get a decent multi meter and test resistance from
Trigger 1 to ground,
and Trigger 2 to ground.
they should both read the same resistance,
and off the top of my head 200 to 400 Ohms?
as long as they are the same anyway.
If they are different it is wired wrong.
Next test AC voltage on the same while cranking the engine over,
( with no ecu
Trigger 1 AC voltage should be a lot higher than Trigger 2 voltage.
If they are the same you have the two sync signals but no crank signal,
if trigger two is higher than trigger 1, then the two triggers are reversed.
Test and report back.
Postby TRD_ZERO » Wed Jan 27, 2010 10:53 pm
That sort of step by step testing and fault finding is what im after. Ill do the test after work tomorrow and let u know.
Im testing with the multimeter at the link plug end right?
Previous:
TRD_ZERO
