Using too much fuel??
Postby Dell'Orto » Mon Feb 01, 2010 6:26 pm
Not using Mobil 98 E10 are you?
Postby TRD_ZERO » Mon Feb 01, 2010 9:14 pm
Dell'Orto wrote:Not using Mobil 98 E10 are you?
No im not.
Previous:
TRD_ZERO
Postby maddog » Sun Apr 11, 2010 7:25 pm
sergei wrote:If temp goes down on highway your thermostat is poked.
I've noticed that the temp. gauge in my 101 FX GT acts the same as TRD_ZERO describes; I've also heard of this exact same behaviour from a work colleague's 101 FX GT, can anyone shed some light on this?
-- 1992 AE101 Corolla FX-GT --
maddog
Postby sergei » Sun Apr 11, 2010 8:01 pm
I had exactly same problem on my AE101, I pulled out thermostat only to find out it was jammed open, I have seen a few other AE101 with similar problem. Even my ST205 had similar problem .
Postby matt dunn » Sun Apr 11, 2010 9:21 pm
If the temp drops on the open road compared to normal,
the it will use more fuel as it will be running on cold fuel program.
Postby sergei » Sun Apr 11, 2010 10:18 pm
matt dunn wrote:If the temp drops on the open road compared to normal,
Not only that, but also it will go into pre-warm mode if outside is cold enough : no VVT, lower rev limiter etc.
Postby maddog » Mon Apr 12, 2010 1:41 am
time for my thermo to get a looking at then :lol:
maddog
Postby sark.inc » Tue Apr 13, 2010 8:30 pm
cleaning the ISCV could not hurt, guide on here how to, just scroll down a bit.
http://4age20v.blogsome.com/
sark.inc
