AE111 Non Superstrut Shock Absorbers
Postby Mr Revhead » Thu Feb 04, 2010 4:01 pm
The top retainer should have a flat side, and the shock rod a corresponding flat.
so when you have it apart, you can hold the retainer to tighten the nut to a certain point. Then a slight tweak in the car to make sure it's tight.
It doesn't not need to be done up super tight.
I can do it up tight enough by holding the retainer whilset it's out of the car, but always check to see if I can get a bit more when it's inthe car. If the spring is trying to turn, it's tight enough.
Postby Dell'Orto » Thu Feb 04, 2010 5:48 pm
Mr Revhead wrote:
BZG|Bling wrote:How do you stop the shock shaft moving inside the shock?
By doing it how I said, ie undo that top nut before you do anything else. weight of the car helps
Yup, always worked for me too...maybe you need to eat more pies? :lol:
brad@autopartsonline.co.nz ;) Need to hurry up slack web person....tristan?
Postby Bling » Thu Feb 04, 2010 6:26 pm
haha screw you guys, no room for pies in my strict training plan :lol:
Will email you tonight Brad
Postby Subway » Sun Feb 07, 2010 9:35 pm
Contacted Evil_Si about getting him to help put them in, but I may in the end just try myself. How hard could it be...
Certainly beats paying Manukau Toyota $350 a CORNER
Subway
Postby Bling » Sun Feb 07, 2010 9:56 pm
Does that include a shock in each corner and a special back rub? :lol: 8O
Postby Dell'Orto » Sun Feb 07, 2010 10:00 pm
Thats allowing roughly 2 hours per strut 8O Though they're possibly charging retail for them
Postby Subway » Mon Feb 08, 2010 11:34 pm
Anyone in Auckland keen to give me a hand? Evil_si is busy for a while and I want to get it done soon, copious beer in exchange?!
Subway
Postby blindnz » Tue Feb 09, 2010 9:20 am
I did a set of fronts for the first time the other week and it was all good, the only thing i forgot was getting the locator on the shock in the right place, like BZG was saying it kept spinning and i couldnt tighten it, a good thrashing wiggled it into place and i was all done.
Give it a go if you've got the tools, the only thing i was a bit dodge about was spring compressors. i kept checking that wherent captive cause i didnt want to get the spring in the face when taking the tophat off.
blindnz
Postby tsoob » Tue Feb 09, 2010 11:46 am
to the o/p i can fit them for you $50 bucks will have it done in NO time at all
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Subway » Fri Feb 12, 2010 2:21 pm
Nick/Tsoob is a legend. Had the car in and out in no time, would def go back again. Took it for a wheel alignment, needed new sway bar links, but ah well. These things happen.
Subway
Postby Bling » Fri Feb 12, 2010 2:59 pm
Even though I can do it myself, for 50 bucks I think i'd be getting him to do it too :lol:
