bracket on silvertop 4age
Postby AceSniper » Tue Feb 23, 2010 2:12 pm
2nd pic is my engine... yes 7a sump.
3rd pic is support bracket, fe's have the same one as 20v's .... all the 20v ones iv seen have had 4afe cast on them :D
If your badly after one ill have 1 or 2 laying around here in Hamilton.
do your cam covers fit around the 4afe mount ok?
AceSniper
Postby matt dunn » Tue Feb 23, 2010 6:28 pm
CAMB01 wrote:Thats because its not a sump, its a bellhousing bracket
That alloy part,
I'd call it a sump, well 1 part of a 2 piece sump.
AceSniper wrote:2nd pic is my engine... yes 7a sump.
7AFE two piece sumps? I'll buy one of you have it.
Postby AceSniper » Tue Feb 23, 2010 6:54 pm
nah i have the 4a supports only spare
AceSniper
Postby sark.inc » Tue Feb 23, 2010 8:12 pm
umm i am sure they sorta won't but i can "make" it fit, but i am worried as you mentioned it helps support the head, where as the 4afe one only has the three bolts to the engine.
also that alloy casting thing at the bottom also seems to cover the flywheel as the metal plate between the gearbox and engine has a hole in it and i can see the flywheel D:
sark.inc
Postby AE25 » Tue Feb 23, 2010 11:27 pm
do you have an automatic? that lower section is probably unboltable so you can get at the torque converter bolts and you may be missing the lower steel plate.
pictured here http://www.trademe.co.nz/Browse/Listing.aspx?id=273425598
you only need to 'support' the block. the head bolts down pretty hard to the block so the head doesn't need support. any braces around the mounts are likely to support the mount itself so it doesn't break
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby sark.inc » Wed Feb 24, 2010 6:39 pm
A picture speaks a thousand words as they say..
here is what i mean
p.s no idea wtf all that white stuff is.... think it's cat litter dust..
p.s freshly rebuilt block and head :twisted: :P
sark.inc
Postby AE25 » Mon Mar 01, 2010 12:40 am
does your sump step in on the intake side.. under about where the starter motor sits? if yes then this block uses the alloy gearbox brace. i have one spare which came from a BT 20v. has 4afe cast into it. $10
looks like you have an auto backing plate.. due to the hole in the center which is for undoing the torque converter bolts. does all the gearbox bolts match up to the backing plate holes?
E2 & E7 fanatic
AE25
Postby sark.inc » Wed Mar 03, 2010 6:15 pm
not to sure what u mean by step?
sark.inc
Postby AE25 » Thu Mar 04, 2010 9:17 am
on the intake side of engine
pic taken from this thread
http://www.6gc.net/forums/index.php?showtopic=68083
E2 & E7 fanatic
AE25
