3sgte Oil pumps
Postby XS1V » Wed Mar 10, 2010 11:21 am
I run a gen III Pump and sump etc to eliminate the inherent gen I/II Problems and it also has a higher flow. Do need to change to a gen III Cam belt as well though and work out which solutions you want for the two oil filter locations :lol:
Always fit new pumps to new/rebuilt motors.......... Not so expensive when this happens, have seen it so many times :roll:
Brad
ST205 Group A Rallye #2363
XS1V
Postby CelicaGT8 » Wed Mar 10, 2010 10:00 pm
Yea im with you on that, just got a new genuine oil pump, last one in the country. Should be good,
CelicaGT8
Postby Boosted_162 » Mon Apr 26, 2010 8:42 pm
Random question...kinda on topic.
Im fitting a new TGP pump and housing to my gen 3. I see there is a gasket that goes around it. Should i replace it with a TGP gasket (is there even an option?) or should i just crack out the silicone gasket goo?
