Injector duty cycle??
Postby sergei » Sat Mar 06, 2010 3:42 pm
TRD_ZERO wrote:so wat do i do with the hose that goes to the pcv valve? As people on here frown apon it when its pluged into the pcv valve. Can i just block it off? And ill put the hose from the pcv valve into a catchcan.
If you are going to use catch can on both ends, then ditch the PCV valve entirely (block the tube on manifold that is normally connected to the valve).
