MAGN1T wrote:JustinSpiderholden wrote:MAGN1T wrote:They're rubbish and don't work anyway.
Steve
Really why?
Show real life examples with hard evidence please to please back up your comments
Else $&#$% off
More to the point , proove that it DOES work.
The theory for carbys is different because you want to keep the fuel cooler to prevent difficult hot starts.
For the average turbo car, the heat in the intake manifold comes from the hot compressed air from the turbos (less than 100% intercooler efficiency).When you're ON boost the intake manifold temp goes up. When you're OFF boost , the intake manifold is cooler.
Reducing any heat soak TO the manifold from the head will make it hotter elsewhere, also the spacer will need port matching very carefully or else instead of only one place to upset airflow due to mismatch, there's 2.
I've had a pair of them on my own car, put them on in 2002, they're in the shed now on a shelf. Rubbish.
Steve
pc wrote:A guy in Canada selling them here http://cgi.ebay.ca/85-90-Corolla-GTS-4AGE-Intake-Heatshield-Gasket-5-HP_W0QQitemZ280473394426QQihZ018QQcategoryZ33668QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If I bought 5 or so it should work out to ~$35 each.
group buy anyone?
Steve
Really why?
Else $&#$% off
Steve
Affroman wrote:You will find that these plates are not to have a cooler intake manifold so the incoming air is cooler, but to have a cooler fuel supply. Hot fuel is just as good for making power as hot air.
This is the same reason why they are used under carburetors
ChaosAD wrote:
Isn't hot fuel bad, and the reason for not wanting to choose a fuel pump too large for the application?
sergei wrote:Not true, hot fuel is great at increasing efficiency.
iOnic wrote:sergei wrote:Not true, hot fuel is great at increasing efficiency.
So what you're saying is that hot fuel is good?
IN: International Symposium on Air Breathing Engines, 8th, Cincinnati, OH, June 14-19, 1987, Proceedings (A87-46176 20-07). New York, American Institute of Aeronautics and Astronautics, 1987, p. 193-199.
The influence of fuel temperature on mean drop size and drop-size distribution is examined for aviation gasoline and diesel oil, using three pressure-swirl simplex nozzles. Spray characteristics are measured over wide ranges of fuel injection pressure and ambient air pressure using a Malvern spray analyzer. Fuel temperatures are varied from -20 C to +50 C. Over this range of temperature, the overall effect of an increase in fuel temperature is to reduce the mean drop size and broaden the distribution of drop sizes in the spray. Generally, it is found that the influence of fuel temperature on mean drop size is far more pronounced for diesel oil than for gasoline. For both fuels the beneficial effect of higher fuel temperatures on atomization quality is sensibly independent of ambient air pressure.
Crampy wrote:MAGN1T wrote:JustinSpiderholden wrote:MAGN1T wrote:They're rubbish and don't work anyway.
Steve
Really why?
Else $&#$% off
Steve
I would hazard a guess that the reason why your ones didn't work was due to having a BHG, which would have caused unusual thermal issues with your motor.
How does that feel?
Crampy wrote:http://www.hondata.com/heatshieldgasket.html#Details
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
FLAWLES wrote:Crampy wrote:http://www.hondata.com/heatshieldgasket.html#Details
thats a good fast read, 3% power increase is dam good for the money, ever car would be different, but still the facts are there
alsoFact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
was very interesting
now i wonder if they make them for a 1jzgte lol, i would happily invest in one
