ChaosAD wrote:Regardless of the brand, an a/f gauge with a narrowband oxy sensor tell you SFA
Yes! This was my point in the beginning of the thread.
FLESHAXXE wrote:I have recently changed the 02 sensor on my 20v levin and I have noticed that the air and fuel guage is reading rich all the time...and on top of that when the car is first started it takes about 4-5mins for the guage to start reading and when it does there is no backward and foward movement of the reading on the guage.....it's and Auto Meter guage...
iOnic wrote:FLESHAXXE wrote:I have recently changed the 02 sensor on my 20v levin and I have noticed that the air and fuel guage is reading rich all the time...and on top of that when the car is first started it takes about 4-5mins for the guage to start reading and when it does there is no backward and foward movement of the reading on the guage.....it's and Auto Meter guage...
The 4-5 minute thing is normal. Where is the gauge spliced into the O2 wiring? Also what ECU do you have? I noticed you mentioned your mechanic tuning it? What sensor did you use when you replaced it? Also how did the gauge behave with the old sensor and why did you replace the sensor?
Regardless of whether the sensor is a narrowband or wideband - the reading should still change under different conditionsInstead of telling the guy to buy other stuff how about maybe trying to help him with his actual problem?
FLESHAXXE wrote:I have the stock ECU......I too thought that the Autometer brand was a very good brand.I will try what you said sergei....
