wiring
Postby touge_ae101 » Wed May 12, 2010 4:07 am
oh shit sorry i was meaning phil bradshaw. both pages are really helpful when it comes to 20v's!
touge_ae101
Postby sark.inc » Wed May 12, 2010 7:04 pm
can't open that with wordpad :cry:
sark.inc
Postby MAGN1T » Wed May 12, 2010 10:09 pm
Generally cars fuel pumps are controlled by the ECU so that when it stalls, the pump turns off. It won't start either until the motor cranks.
It's also a bad idea feeding 12V to places it shouldn't be.... you'll kill something.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby touge_ae101 » Wed May 12, 2010 10:21 pm
sark.inc wrote:can't open that with wordpad :cry:
its just a word file?i can send in PDF format if you want?
touge_ae101
Postby sergei » Wed May 12, 2010 11:18 pm
Or get an openoffice. It is free.
Postby sark.inc » Tue May 18, 2010 7:22 pm
cheers :D
sark.inc
Postby sark.inc » Thu May 27, 2010 8:36 pm
here is my average diagram
http://www.iforce.co.nz/View.aspx?i=apuhwgoi.jpg
when you start cranking the engine over, 12v is taken from the starter to open the relay, so the 12v from ignition or where ever you took 12v from can flow through the open circuit relay to the fuel pump, once the engine has enough air flow (engine running) the air flow meter acts as a earth for the open circuit relay and allows current to flow from the 12v source to keep the open circuit relay latched and allow power to flow to fuel pump allowing it to well pump :)
also 12v is taken from the starter to the ECU.
p.s the ECU does not actually control the fuel pump, the airflow meter does, it's simply on or off.
sark.inc
