inlet plenum designs
Postby fivebob » Thu May 20, 2010 3:27 pm
RomanV wrote:So it seems like a bit of a misnomer to say that smaller runners get better velocity, if you have small runners and large ports, you're most likely going to get less velocity at the port entrance than if you had a runner size which maintains the cross sectional area.
But you're forgetting about the momentum of the air mass that's moving through the runners. If it has greater velocity then it will have more momentum and therefore slow down less when it encounters the larger port ;)
Postby tsoob » Thu May 20, 2010 6:20 pm
what about making the runners the same shape as the ports?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
